Old 08-21-2014, 07:14 PM   #1
trinxified
Drives: Subaru BRZ Aozora Edition
Question Are sway bars good for street daily driving?
I'm looking to get front and rear sway bars... How much difference will they be for street daily driving?
Are they a good buy for street use only?
trinxified is offline   Reply With Quote
Old 08-21-2014, 07:20 PM   #2
Sleepless
Drives: 2016 FR-S
Last thing these cars need is sway bars...
I don't like them on the streets; prefer stiffer springs.
Sleepless is offline   Reply With Quote
Old 08-21-2014, 07:26 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I'm on the fence about them.
I always believed sway bars are a last tier modification, only do them on cars that truly need a handling improvement or if you've done everything you can already.
Just my view on em....
Edit: I rembebr sway bars on a BMW 2002, that was a massive improvment in handling. The 2002 were good handling cars in the first place, but always suffered a big amount of body roll.
Old 08-21-2014, 07:57 PM   #4
themajesticone
themajesticone's Avatar
Drives: '13 UM86
If anything a front strut may be the only 'close-to-functional' piece out of the two, but realistically it won't do much at all. Do you plan on driving everywhere in the street like you are at the track or auto-cross?
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 08-21-2014, 07:58 PM   #5
Gunman
Drives: 2019 Mazda Miata RF
I put adjustable ones on mine, and I can tell the difference, and I only drive on the street. ARB's should be a tuning device, and even as a non-driver (I design race cars, I don't drive them), I could tell when I installed them, that the rear was too loose, and the front bar needed to be adjusted.
That said, you also feel every single side bump more, since the ARB is increasing the spring rate on that side, so the ride gets rougher. Along with the springs, the ride got rougher, but not unbearable.
Gunman is offline   Reply With Quote
Old 08-21-2014, 08:18 PM   #6
Createddeleted
Drives: 2014 BRZ - 2004 GLI
I loved mine. The car felt much safer on the road. IMHO. (On stock springs)
Sold them as I'm just going to install coilovers. Didn't feel like I needed both.
Createddeleted is offline   Reply With Quote
Old 08-21-2014, 08:22 PM   #7
CSG David
CSG David's Avatar
Stay stock. Swaybars are used for fine tuning. You can gain a lot with proper coilover or shock/spring setup.
Old 08-21-2014, 08:30 PM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
With such a low COG I thought body roll wasn't an issue, especially for the street. Stiffer sway bars and or adjustable/ end links might be a waste of $ compared to other more impactful mods at this level.
If anything I'd go with Koni or Bilstein sleeves.
Old 08-22-2014, 08:02 AM   #9
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
What coilovers are you running on the CSG BRZ/FRS?
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 08-22-2014, 10:58 AM   #10
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I agree with the majority. I purchased swaybars, but for autoX. The stock suspension is more than adequate for street use.
-Jack Burton
Old 08-22-2014, 12:26 PM   #11
CSG David
CSG David's Avatar
TEIN SRC - CSG Custom Prototype valving spec
In between revalving and reworking the internals on the SRCs, we're on stock shocks with Swift Spec-R springs + Raceseng CasCam plates. I recommend running a Bilstein or Koni with this spring as the spring rates are hitting the absolute limit of the stock damping curve.
sway bars shehan1212 NY / NJ / CT / PA 1 03-18-2014 10:17 PM
BRZ / F86 Sway bars timlewis82 Australia Classifieds 3 02-02-2014 03:06 AM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 01:43 AM
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 03:11 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
