Old 07-24-2014, 01:40 AM   #1
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
What is this clicking sound coming from under the rear of my car?
I have a clicking sound that I can hear whenever I'm at a stop then go, or from stop into reverse, or even when I'm decelerating then give it some gas. One of my two videos I'm in my garage at a stop. Then I put it into 1st and go a little. Then stop. Then reverse a little. In the other video the car has the e-brake on and I'm using my arms to pull back and forth on the rear driver's side wheel. The sound seems slightly stronger on that side vs me pulling the passenger side back and forth.
I have a track day in two days and I don't want to blow up my car. I ran it at a track day a few weeks ago and nothing bad happened and the car seemed fine aside from the clicking. Same with when I went drag racing; nothing bad happened. It's been happening for about 4 months or so.
@CSG David or @CSG Mike or @Drift-Office or @Jason@Nameless any ideas?
[ame="http://youtu.be/1g9eaVS-EgE"]http://youtu.be/1g9eaVS-EgE[/ame]
[ame="http://youtu.be/LATURgwKTmM"]http://youtu.be/LATURgwKTmM[/ame]
[ame="http://youtu.be/bR10jx5fUdg"]http://youtu.be/bR10jx5fUdg[/ame]
stockysnail is offline   Reply With Quote
Old 07-24-2014, 02:33 AM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Sounds like a metal part is hitting another metal part. Have you checked if anything is loose in the rear or if there is little clearance between two parts?
Bach415 is offline   Reply With Quote
Old 07-24-2014, 11:17 AM   #3
stockysnail
Just the tip
Yes I didn't see anything.
Old 07-24-2014, 11:48 AM   #4
Wepeel
Drives: '13 BRZ Ltd
If I have the ebrake on, and the trans in neutral, and rock the car back and forth, I get this clicking/tinking on both sides. It seems like it's coming from the ebrake drum or something. Have had it for a while. Doesn't make the noise if the ebrake isn't on.
Wepeel is offline   Reply With Quote
Old 07-24-2014, 01:10 PM   #5
Bach415
Bach415's Avatar
Have you installed anything prior to this noise?
Old 07-28-2014, 10:12 AM   #6
stockysnail
Just the tip
I can't think of anything I installed when the clicking started.
Old 07-28-2014, 11:50 AM   #7
silverbullet
Drives: 2013 BRZ LTD Silver
It might be the ebrake retaining clip. Mine broke about a month ago and started making a metal on metal "clink" sound whenever stopping or just starting from a stop. Can't tell from your vids if its the same sound but it very well could be.
silverbullet is offline   Reply With Quote
The Following User Says Thank You to silverbullet For This Useful Post:
stockysnail (07-28-2014)
Old 07-30-2014, 01:50 AM   #8
stockysnail
Just the tip
Where is the ebrake retaining clip? Is it at the end of the ebrake cable on both sides?
Old 07-30-2014, 02:24 PM   #9
silverbullet
I'm not sure unfortunately. I figured out what the problem was from someone on another forum with the same issue. Haven't opened anything up yet myself. If I beat you to it I'll post what I find here.
Old 07-30-2014, 03:25 PM   #10
chicagokid
Club Member
chicagokid's Avatar
Drives: 2014 Asphalt FR-S Monogram 6MT
I have this same noise too. Keep us posted.
I think it's just on manual trans.
chicagokid is offline   Reply With Quote
Old 07-30-2014, 05:52 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
http://www.ft86club.com/forums/showthread.php?t=13451
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-03-2014, 03:20 PM   #12
stockysnail
Just the tip
Originally Posted by Kodename47 View Post
That's definitely not the same issue or clicking I'm hearing. If you listen to my videos and read my post you'd agree. My pop or loud click is coming from the rear inside wheel, axle, or differential area and I can make it happen without driving the car but with moving the rear wheel by hand.
Old 08-03-2014, 08:16 PM   #13
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Are you lowered? this could be your problem!
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
whataboutbob (08-05-2014)
Old 08-04-2014, 10:45 PM   #14
stockysnail
Just the tip
I am lowered a little (0.8"). I'd rather not rip open my axle bushing unless I know that's the issue, unless someone has an x-ray machine I can borrow to see through the rubber. I wonder if I push down hard on the rubber and tried to feel is there was any cracked metal, if that would work for checking...
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 06:58 AM
Clicking coming from rear.. HillCountryGuru Issues | Warranty | Recalls / TSB 3 03-22-2013 12:05 AM
Fixed flapping, clanking sound coming from rear Cornerman Issues | Warranty | Recalls / TSB 2 08-16-2012 09:27 PM
