Old 05-30-2012, 03:53 PM   #1
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
BRZ/FR-S/GT86 Air Filter equivalents
The BRZ comes with the Toyota 17801-22020 filter from Denso.
Equivalents:
K&N: 33-2252
Purolator: A25463
Purolator PureONE: PA25463
Fram: CA9482
The cabin air filter does not have a part# on it. If anyone at Subaru or Toyota have the part#, I'd appreciate it. Thanks.
Btw, easiest cabin filter to change ever!
The Following 6 Users Say Thank You to Draco-REX For This Useful Post:
Black Tire (03-07-2013), ESBjiujitsu (05-30-2012), Fly Guy (05-30-2012), Jayde (05-30-2012), pkny (05-30-2012), Primo86 (05-30-2012)
Old 05-30-2012, 04:36 PM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I always just get large furnace filters and cut them to size, they work just as well in my experience and you get 2-4 or more sometimes for nine bucks.
michaelahess is offline   Reply With Quote
The Following User Says Thank You to michaelahess For This Useful Post:
charged86 (02-24-2014)
Old 05-30-2012, 04:39 PM   #3
pkny
Drives: Firestorm FR-S 6MT
K&N: 33-2252 is also for 1st gen scion tC. Well, that means afe wet type 30-10094 and dry type 31-10094 will fit.
pkny is offline   Reply With Quote
Old 05-30-2012, 04:42 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
That's odd. I list a K&N 33-2300 for the 05 tC. But I also list the same Purolator as above (A25463). Strange.
Old 05-30-2012, 04:54 PM   #5
pkny
The only different is height. 33-2300 is 27mm, while 33-2252 is 25mm. 05-06 tC uses 33-2300, and 07-10 uses 33-2252. The one from TRD and aFe has 25mm height, which is for 05-10 tC. Some said TRD USA uses afe as their oem, but I am not sure.
Old 05-30-2012, 04:57 PM   #6
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
great info
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-30-2012, 05:03 PM   #7
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
I pulled the cabin air filter from one of the cars and it wasn't the same as any other Toyota models. Maybe it's the same as a Subaru? FR-S part numbers don't really cross over well to other Toyota models, but the Toyota part number for the cabin filter is SU003-02112.
For the engine air filter:
Toyota: 17801-22020, 17801-0D020 or SU003-00319
TRD USA: PTR43-00085
Fits 03-08 Corolla/Matrix, 05-10 Scion tC, and 13+ Scion FR-S.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following 2 Users Say Thank You to Jeff Lange For This Useful Post:
Bristecom (02-24-2014), Fly Guy (05-30-2012)
Old 05-30-2012, 05:05 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
I was about to pick up the K&N but since the MAF is so close to the element, I decided against it. I might pick up a dry nano filter.
Old 05-30-2012, 05:17 PM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
Just got off the phone with Purolator again. That number doesn't cross. Which is possible as I don't think they make some Subaru filters. The home HVAC filter idea above is something a lot of Subaru owners do.
Old 05-30-2012, 05:38 PM   #10
Jeff Lange
Jeff Lange's Avatar
Ideally if you wanted to cross reference it, what you need is the Subaru part number, IMO. The part number I gave you probably won't cross to anything yet. It's like how the Toyota part number for the oil filter is SU003-00311, while it's actually a Subaru 15208-AA130 oil filter in the box, which is more easily cross-referenced.
Cross referencing Toyota 86/FR-S parts is complicated/hard because the car has unique part numbers that don't match up with other Subaru or Toyota part numbers. They are just FR-S part numbers, and that's it.
So my suggestion is to get the BRZ part number for the cabin filter and try to cross reference that instead.
Jeff
Old 05-30-2012, 05:48 PM   #11
pkny
AFe dry air filer is good. No oil, no mess. Only $30 when I bought it. I used that on my tC for 5 years without problem. I got >120k miles on my tC before someone rear ended and total it.
Old 06-03-2012, 08:22 PM   #12
grst1
grst1's Avatar
Drives: '94 Ford Aspire
Subaru BRZ Replacement Cabin Air Filter, Part# 72880AJ010
Subaru BRZ Replacement Engine Air Filter, Part# 16546JB000
Subaru BRZ Oil Filter & Gasket Replacement, Part# 15208AA130 & 803916010
Copied from here:
https://www.subaruonlineparts.com/in...446f31e1d6795e
I was hoping to use some of my leftovers filters from my STi but it seems like it won't happen!
grst1 is offline   Reply With Quote
Old 08-13-2012, 12:27 PM   #13
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
Copied from here:
So if I wanted to purchase a cabin filter replacement (when necessary) what aftermarket brand/model numbers would fit? lets say from auto zone or advance auto ?
thanks!
mikeg7827 is offline   Reply With Quote
Old 08-13-2012, 07:48 PM   #14
Draco-REX
Corner Junkie
Draco-REX's Avatar
thanks!
I'll try to remember to cross this when I get in to work tomorrow. But I'm not sure there's a cross just yet. You shouldn't need to replace it for a while. But if you really want to, one of the things a lot of Subaru owners do is get a home HVAC filter and cut it to fit.
Oil Filter Locale? GT86 Redneck Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-22-2014 03:47 PM
Which oil filter for the FA20? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 07-09-2012 01:21 PM
Oil Filter Brett Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 05-23-2012 10:53 PM
Got my first FR-S part in today (Oil Filter) Jeff Lange Scion FR-S / Toyota 86 GT86 General Forum 5 05-05-2012 05:12 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 04:35 PM
