Old 04-30-2012, 03:29 PM   #1
GT86 Redneck
GT86 Redneck's Avatar
Drives: 2011 GMC Sierra 5.3L 4X4
Oil Filter Locale?
So when gawking at pictures of the under hood of an FRS I saw the oil filter and though that putting It on top of the engine was ingenious! In my little Toyota truck you have to stick a screwdriver through the filter to get it out . But what about when you change the oil, isn't the oil going to come pouring out and get all over the engine?? Heres a pic below where you can see the black oil filter midway down right in the engine bay.
GT86 Redneck is offline   Reply With Quote
Old 04-30-2012, 03:48 PM   #2
Lytheum
Drives: 2013 BRZ Premium 6MT
think it was discussed that it sits in a cup. so as long as you take it out slowly it should drain in the cup and not cause a mess.
Lytheum is offline   Reply With Quote
Old 04-30-2012, 03:49 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
We already have discussion, but... Nope, it won't.
If you look at current Toyota trucks you'll see same design for oil filter. When you want to change the filter, there's a lil tube that coming out around and you'll just connect it w some hose. It's easy & a lot cleaner to change oil filter this way
ESBjiujitsu (05-16-2012)
Old 04-30-2012, 04:08 PM   #4
Turbowned
Turbowned's Avatar
So much more convenient than having it underneath and draining oil all over axles, hoses, electronics, etc. when you pull the filter! In my first MR2 the A/C compressor and exhaust header were both there to melt your hand if you tried removing the filter with the engine too hot. In my MR2 Turbo it was also near impossible to get a handle-type oil filter wrench over and have any room. Then I discovered the filter wrench that takes a 3/8" drive extension and wratchet... Still a PITA.
Old 04-30-2012, 04:33 PM   #5
OrbitalEllipses
Drives: Attitude
Way better than oil filter placement on the EJ. Exhaust manifolds WILL burn you.
Old 04-30-2012, 04:39 PM   #6
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah, I much prefer this location/design. Just stick some paper towels under it after it drains out.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 04-30-2012, 06:19 PM   #7
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
The only concern I have is with a bottom mounted oil filter, I can pre-fill the oil filter with oil before installing. With top mounted filter, we won't be able to do it anymore.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 04-30-2012, 06:20 PM   #8
trackmagic
Drives: 1994 BMW 318i
The only times I have to stick a screwdriver through a filter is if I take my car to one of those speedy-oil change places. Those guys either tighten to the point where you can't take it off or it is so loose that it vibrates off on your way home.
trackmagic is offline   Reply With Quote
Old 05-01-2012, 01:24 AM   #9
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
with a filter that small it's not necessary. my tacoma has 150K miles on it and has no issues with the inverted oil filter. it's in basically the same spot and it's silly-easy to change. <3 it. i'm very pleased they went with a similar design here.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 05-16-2012, 02:33 PM   #10
MTeator
First 86
On my 93 MR2 with the upside down oil filter I just would poke a hole in the end with an awl so it'll drain out when I drain the rest of the oil. Then when I unscrew it... no oil to go everywhere.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
The Following 2 Users Say Thank You to MTeator For This Useful Post:
chulooz (05-18-2012), Dadhawk (05-16-2012)
Old 05-17-2012, 11:47 PM   #11
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
Funny, this was the second thing I took apart on our car. I had to know if oil was going to dump out into the cup. NOPE!
No wiping up of anything! There is only one downfall. Dirt will get in there over time, so it may be one of those things where you have to wash/wipe out the dirt with each change. Not a big deal though.
PERRIN_Jeff is offline   Reply With Quote
The Following 6 Users Say Thank You to PERRIN_Jeff For This Useful Post:
civicdrivr (05-18-2012), Dadhawk (05-18-2012), Fly Guy (05-18-2012), Lone (05-24-2012), MarkRacerX (05-18-2012), Ryephile (05-18-2012)
Old 05-23-2012, 10:28 PM   #12
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Looks like I will find out tomorrow.
tonystewart is offline   Reply With Quote
Old 05-26-2012, 02:15 PM   #13
tonystewart
Mobil M104 fits great!
The Following User Says Thank You to tonystewart For This Useful Post:
civicdrivr (05-26-2012)
Old 05-28-2012, 10:56 PM   #14
IceCreamMan
Decepticon
Drives: 2013 Scion FR-S (Asphalt 6MT)
This may be the greatest oil filter placement I have ever seen!!
2013 Scion FR-S Asphalt 6MT
IceCreamMan is offline   Reply With Quote
Which oil filter for the FA20? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 07-09-2012 12:21 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 03:35 PM
