Northern California NorCal
Old 08-11-2014, 06:56 PM   #1
merino_frs
merino_frs's Avatar
10mm bolt broke when installing Supertek hood dampers
Hey guys,
So I was installing the Supertek hood damper kit and I was almost done when the 10mm bolt from the drivers side broke off. The threaded part is still inside the hole and the top half is in my hand. Any suggestions on how I can take it out? Thanks guys!
merino_frs is offline   Reply With Quote
Old 08-11-2014, 07:18 PM   #2
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
If there are any threads showing, you could 'carefully' put a pair of vice-grips on to unscrew it or perhaps grind a slot to take it out with a screwdriver. If the bolt is broken off in the threaded area, you will have to use an easy-out after drilling a small hole into the bolt leftovers. I am in Modesto, I may be able to help or give additional advice with a pic or in person (I have most of the tools and perhaps a small enough easyout).
Eric G
mkiisupra is offline   Reply With Quote
Old 08-11-2014, 07:27 PM   #3
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
if u cant get to any exposed threads and its deep inside and you dont have access to easy outs. you might be able to keep threading it in until it falls out the other side. if the hole is a thru hole you might be able to take a regular drill bit to bite into it to push it out the other side.
garfull is offline   Reply With Quote
Old 08-11-2014, 07:39 PM   #4
HapaHaole
Drives: Grocery cart
Originally Posted by garfull View Post
if the hole is a thru hole you might be able to take a regular drill bit to bite into it and thread it all the way thru until it falls out the other side.
Make sure you use a left hand thread drill bit, if not you will be screwing in the broken bolt even further in .
If you can do this.. get smaller bolt that will cover the exposed bolt, and get super glue and stick it on there for a few min.. then try to work it back out.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 08-11-2014, 07:53 PM   #5
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Eric G
Listen to this guy^^
BirdTRD is offline   Reply With Quote
Old 08-11-2014, 08:00 PM   #6
merino_frs
merino_frs's Avatar
Thanks for the input guys @mkiisupra I'm also in modesto. I'll try your advice and if all fails I could definitely use your helping hand. Thanks a lot fellas
Old 08-11-2014, 10:13 PM   #7
acx23
Drives: 2013 FRS (Silver)
I've broken a valve cover bolt before. I drilled a hole big enough to jam a torx screwdrive in, and backed out the broke off thread.
acx23 is offline   Reply With Quote
Broke the stock overpipe bolt :/ Sniper2606 Engine, Exhaust, Transmission 44 04-26-2015 01:19 AM
10mm bolt broke merino_frs Cosmetic Modification (Interior/Exterior/Lighting) 7 08-11-2014 08:45 PM
Supertek hood dampers mightyt73 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-21-2014 11:41 PM
***SuperTek Carbon Hood Dampers - Install DIY*** FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 3 05-18-2014 08:16 AM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 02:47 AM
