Old 08-08-2014, 09:22 AM   #1
Boots1994
Drives: Scion FRs 2015
Third to Second Jackhammer Noise
Hi guys, So I bought a 2015 Scion FRS maybe 3 weeks ago, its got aroung 550 KMs on it; however, I've experienced this issue twice. Let me first preface this by saying that, yes, my foot is all the way to the ground and no it does not have that distinct gear grinding sound.
In my 550 Kms driven, twice on my shifts from third to second I have gotten this weird resistance in the shifter followed by a noise that sounds like a jackhammer under the car. I do not believe the noise is RPM dependent. Upon hearing this noise I put the car in neutral and then put it back in gear with no problems afterwards.
I think this could be because the gear is not fully engaging, ie: the stick might be half way from neutral to second but I'm not entirely sure whats going on.
My questions are: What do you think this issue is? And do you think it is doing serious damage to my car? I mean, it's happened twice now and the noise probably happened for 1 or 2 seconds before I immediately put it to neutral to stop the noise, but it's bothering me to know that this may be doing damage to my car.
Any help will be greatly appreciated.
Boots1994 is offline   Reply With Quote
Old 08-08-2014, 02:32 PM   #2
humfrz
You might try double clutching and/or rev matching.
If that doesn't work, I'd suggest you take it back to the dealer for a look see.
While you you are there, ask them if you could drive another FR-S MT, to see if it does the same thing (confirming or sorting out pilot error ....).
humfrz
Old 08-08-2014, 03:03 PM   #3
Darkazn58
Drives: 2014 Subaru BRZ
Is it a crunching kind of feeling? Can you post a sound clip? Like most everyone else, I had difficulties with 2nd as well. But after replacing the tranny and diff fluid with motul 300, things got a lot better. Then with another 2000 miles or so things got smoother.
Darkazn58 is offline   Reply With Quote
Old 08-08-2014, 05:14 PM   #4
Boots1994
It's not a crunching noise, it's a metal on metal sound... like a jackhammer. Like this.. [ame="https://www.youtube.com/watch?v=0piYZOLjiwQ"]jackhammer sound - presslufthammer geräusch - rumore martello pneumatico - YouTube[/ame]
Is it hard to change transmission fluid?
Old 08-08-2014, 06:33 PM   #5
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
It's easy to change the fluid, but I would recommend for you to put some more miles on it, and see if it gets better. It's a brand new car, so all the parts need time to wear in.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Road noise? Tread Noise? zERoTu Issues | Warranty | Recalls / TSB 21 10-07-2020 10:21 PM
Is it THAT noise? Taro Issues | Warranty | Recalls / TSB 5 09-23-2013 09:21 AM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 05:22 PM
LSD noise wheeladdict CANADA 2 07-09-2012 03:21 PM
