Drives: 2015 BRZ
USB hard-wire install
I'm using an old Galaxy S3 to run torque, Waze and listen to audio books. I have it mounted on a low profile mount in the top left corner of the windshield near the pillar.
I want to hard wire a usb cable, but I want to make sure I'm getting enough to maintain a charge and not just slow down the battery drain. My plan is to cut a factory USB cable and short wires 2 and 3. Then connect to this: [ame="http://www.amazon.com/dp/B00A71CMDU/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1D8X B8X6N6PBF&coliid=I3MO6QIT1AV1U8"]Amazon.com: KEEDOX® DC/DC Converter 12V Step Down to 5V 3A Power Supply Module: Electronics[/ame] and then use an add a fuse to the panel under the driver's side dash. I don't want constant power, only while the car is on. Run it up the pillar and down from the headliner, nice and clean and pretty. Thoughts? Will this be sufficient? |
Custom User Title
Drives: Asphalt FR-S MT
Check the interior fuse box. Some slots only have power with ignition.
Custom User Title
Ah I see. I interpreted that part as something else.
![]() It should easily be more than enough power though. I would crack the charger open to bypass the step down voltage regulator, and place it in line. Otherwise you would kill the battery. Or you can get a 12v charger if you want to avoid opening a wall charger.
| The Following User Says Thank You to boredom.is.me For This Useful Post: | skeet (08-05-2014) |
#5 | |
Drives: 2015 BRZ
Custom User Title
The car is 12v so yes you would still need a step down. It would be easier to just put a 12v (car) charger in line.
Honestly, I have no idea what actually does the charging. I wouldn't be surprised if the charge circuit is in the phone. Why do I say that? Because 5v is probably too much for a single cell. If this is the case, then any 5v source would work. I would still play it safe and put a car charger in line.
Drives: 2013 GBS BRZ Limited
There is a 12V cigarette lighter receptacle in the glove compartment.
Buy a $10 USB phone charger and plug it in there. |
Drives: 2015 BRZ
My dashcam is currently using that, and in the past when I've run USB cables that far it hasn't maintained enough juice to power my phones while using bluetooth and GPS.
Drives: 2015 BRZ
#10 |
Drives: FRS
TBH for this I'd use a simple cigar socket splitter behind the glove box and run the dash cam and phone off it like boredom suggested, its gotta be simpler to try that first than the other route. Is the phone being setup to hibernate when not charging?
| The Following User Says Thank You to Chimera For This Useful Post: | skeet (08-05-2014) |
#11 |
Custom User Title
Ya I go all over the place sometimes. You were originally talking about cutting into the USB wire though. I was just going along with that initial condition.
Tap a 12v source Hook car charger up to it Splice charge supply wires into USB power wires
#12 | ||
Drives: 2015 BRZ
#13 | |
Its dual-port interface features one 5V/2.1A port which is ideal for ultra-fast charging devices such as Apple iPads and other tablets, and one 5V/1A port for Smartphones, iPod, GPS and other devices. http://www.newegg.com/Product/Produc...140805151518:s |
#14 | |
Drives: FRS
that looks cool
| Subaru BRZ Clear bra Install (self healing), Window Tint & Wolf's Hard Body Sealant | Rickrack | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 03-15-2015 02:54 PM |
| DIY request: Gauge install and wire routing | mikepaul21 | DIY (Do-It-Yourself) Guides | 3 | 07-05-2014 12:43 PM |
| Clear bra install woes - Is it that hard? | SHIFTER | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 31 | 05-12-2013 10:48 PM |
| best way to install 12v wire for amp?? | derka-derka | DIY (Do-It-Yourself) Guides | 5 | 03-17-2013 12:57 PM |
| Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 10:22 AM |
