Old 08-01-2014, 02:19 PM   #1
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Hmmm...
What kind of work would it take to add an electric motor to the trunk of this car? Effectively making it a hybrid.
Old 08-01-2014, 02:20 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Go Home, You're Drunk
The Following 11 Users Say Thank You to King Tut For This Useful Post:
BlueDubbinTDI (08-01-2014), cdrazic93 (08-01-2014), Dave-ROR (08-02-2014), gramicci101 (08-01-2014), husker741 (08-01-2014), JohnJuan (08-01-2014), Jrryjms07 (08-03-2014), sklimo (08-01-2014), tahdizzle (08-01-2014), Toca (08-01-2014), ZDan (08-02-2014)
Old 08-01-2014, 02:28 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The only other way to get more power and better fuel economy would be to turn it into a turbo diesel.
Old 08-01-2014, 02:34 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Go Home, You're Drunk.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
gramicci101 (08-01-2014), tahdizzle (08-01-2014), ZDan (08-02-2014)
Old 08-01-2014, 02:36 PM   #5
sklimo
Old 08-01-2014, 02:49 PM   #6
hypercarfanatic
Drives: Own F-150XLT, Lexus RX300
^ This
I get what you are trying to do, increase torque ect., but trying to put in a whole electric engine will cost a shit ton. Not only do you have to get the engine, but you need to reconfigure the engine bay along with just about everything else.
I know next to nothing about swapping engines, but I do know that undertaking something like this would be so cost intensive that you would be better off building an engine for more power.
My .02
hypercarfanatic is offline   Reply With Quote
Old 08-01-2014, 03:37 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Purely from an engineering standpoint, people make lawn mowers do 130 and V8 barstools. It's not about being cost efficent. It's about whether it's feasible or not. There's many a time I find myself thinking wild and crazy ideas just because I can. Sure it would cost probably 2-3 times what the car is worth, but it would be the first of it's kind and one hell of a project.
I could have reiterated all your comments 2 years ago about turbocharging a stock motor with 12.5:1 CR. Think outside the box people.
Old 08-01-2014, 04:34 PM   #8
gramicci101
Off Topic
It would add a LOT of weight to the rear end of the car. Large electric motors and their storage cells are heavy as shit. You would need to do a lot of suspension work to make the car handle well again.
What you could do is put a turbine on the driveshaft at the middle joint, use the normal driveshaft rotation to pressurize a hydraulic accumulator, and then when you want launch assist you could dump pressure back through the turbine to spin the driveshaft. You would need something to disengage the clutch when this happened so you don't spin the engine.
Ford did this with their F-350 Tonka concept truck.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 08-01-2014, 04:41 PM   #9
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I wouldn't go fiddling with the Scion.
Get a Fiat X1-9 if you want to build an electric. :-)
NWFRS is offline   Reply With Quote
Old 08-01-2014, 04:48 PM   #10
AJPG
Drives: 22RE, FA20, 4G63
(-_-)
AJPG is offline   Reply With Quote
Old 08-01-2014, 05:05 PM   #11
wheelhaus
wheelhaus's Avatar
Sure it can be done. It would att a lot of weight, it would be terribly expensive, it would require a machine shop, an automotive mechanical engineer, and an electrical engineer at minimum.
But why?
I guess it could be done for shits and giggles, but... So could a lot of things. Like covering the car with shag carpet and giving it cat ears and an exhaust that meows.
wheelhaus is offline   Reply With Quote
Old 08-01-2014, 05:50 PM   #12
strat61caster
strat61caster's Avatar
Gotcha, I'll give you the blueprints for free:
Get two electric motors, associated battery packs and some chain, weld gears to the driveshafts and attach the electric motors with chains (dat S500 sounds). Place 2 buttons on the steering wheel: 1-Discharge, 2-Charge. When you want the go put the car in neutral and hit discharge woop torque, then if you have time before you hit the tree on the outside of the next corner hit charge flipping the motor to a generator which will provide all your engine braking and then-some while charging the battery for corner out powaaah.
Step 2: Go race a 918
wheelhaus (08-01-2014)
Old 08-01-2014, 10:06 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
It's like communism on this forum, you get smacked and/or verbally reprimanded for not thinking like everyone else, good lord.
Old 08-01-2014, 10:08 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by gramicci101 View Post
What you could do is put a turbine on the driveshaft at the middle joint, use the normal driveshaft rotation to pressurize a hydraulic accumulator, and then when you want launch assist you could dump pressure back through the turbine to spin the driveshaft. You would need something to disengage the clutch when this happened so you don't spin the engine. Ford did this with their F-350 Tonka concept truck.
Most helpful post in this thread.
Polaris Slingshot......hmmm....I think I want one! JDB Other Vehicles & General Automotive Discussions 41 01-08-2015 04:08 PM
Jaguar XFR-S...xFR-S...hmmm dem00n Other Vehicles & General Automotive Discussions 5 12-07-2012 03:40 PM
hmmm....Carmax Zaku Off-Topic Lounge [WARNING: NO POLITICS] 6 01-27-2012 09:06 AM
