Old 07-05-2014, 01:57 AM   #1
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Intense rear wheel shudder during e-brake drifts
yes yes... ebrake turns..shouldn't be doing them. In over 2 years of owning the car, I never did a single one...until today..ok we moved on.
I notice when I pull the ebrake to initiate a slide that pushes my RR to the outside, I get an intense shudder in my rear right wheel. I am thinking a marginally lose lugnut, or when I put the wheel on I did not align it perfectly on the hub so when it catches during the drift, it kind of jostles around. I can initiate a turn in the opposite direction and there is no shudder (unless the rear right catches a bit at the end and does it noisy thing) (this was all going quite slow in a parking lot. I was just trying to find out what's up with the noise)
Thoughts anyone? I hope it is something as simple as jacking it up, and mounting the tire again. Could it be something else? Could it just be the e-brake shoe catching?
Thanks guys.
Old 07-05-2014, 02:29 AM   #2
KPark
Drives: none
make sure you torque them right before drift.
KPark is offline   Reply With Quote
Old 07-05-2014, 05:36 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Do you have the nannies turned off? If you are doing handbrake turns you should be doing the pedal dance.
I would initiate turns in motorkhanas using the h/brake without issue but always after pedal dance.
Old 07-05-2014, 12:41 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I didn't do the pedal dance, maybe that is why... had everything "off" but not via the dance (which shuts off all the nannies, as we know)
I torqued the lug nuts when installed, and checked again later. always worth a quick reinstall
Old 07-08-2014, 09:15 PM   #5
wparsons
wparsons's Avatar
The e-brake engages with a clunk even if you're barely rolling, I imagine it's much worse if you're going faster.
flickr
Old 07-08-2014, 09:18 PM   #6
protpibe
protpibe's Avatar
Buddy, you're boosted... power over!
But seriously, that's a pretty weird issue. I would be pulling the rotor off to check out the e-brake innards to make sure all is well in there.
Do you have hubcentric rings on your wheels?
Old 07-09-2014, 01:05 PM   #7
Dezoris
Dezoris's Avatar
Raise rear pressures by 8psi try again
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 02:39 PM
Driveline shudder when lifting off throttle (not touching clutch) NYC BRZ Issues | Warranty | Recalls / TSB 6 10-19-2012 05:35 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
