Old 10-19-2012, 06:34 AM   #1
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Driveline shudder when lifting off throttle (not touching clutch)
Hi folks. I'm not sure if this is more common with other manual cars but I've never experienced this before.
When lifting off the throttle, specifically at lower speeds, I'm getting a shudder for a second or so in the driveline. This is without touching the clutch. If I'm cruising through light traffic say around 25mph and lift the throttle it bucks. Again, I'm no expert in manual transmissions but it doesn't feel right. Thoughts?
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 10-19-2012, 08:31 AM   #2
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
It can do that when the engine is cold, it shouldnt do that when its warm. Also, how many miles are on your motor? New engines that arent broken in are fluffy, slow throttle response etc and can do some things like that.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 10-19-2012, 08:52 AM   #3
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
I've got 5900 on the engine and it happens even after its warmed up. I don't get it. Weird.
Old 10-19-2012, 09:03 AM   #4
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Old 10-19-2012, 11:00 AM   #5
Innova
Drives: 2013 BRZ Limited
This sounds like the oh-so-common idle dip. Mine does it as well. It hasn't caused any issues.. yet
Innova is offline   Reply With Quote
Old 10-19-2012, 01:32 PM   #6
dnL
Drives: Ultramarine FR-S
I think it's normal. It basically feels like engine braking is kicking in hard and fast, right? My FR-S does that after 8000 miles and even when it's warm. I feel like the throttle is just more sensitive than other cars I've driven, but it really only happens when I let off the gas abruptly. I'm just careful about how I let off the gas if I want to avoid it.
dnL is offline   Reply With Quote
Old 10-19-2012, 05:35 PM   #7
Jayde
Jayde's Avatar
It'll be more pronounced if you're in a lower gear. My BRZ does it, my old Integra with 186,000 miles did it, and my friend's Si does it. I'm sure it's normal. Believe, like others have said, it's engine braking.
Jayde is offline   Reply With Quote
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
The BRZ / FR-S / GT 86 transmissions and driveline: what we know so far jruhi4 Engine, Exhaust, Transmission 25 02-17-2012 03:33 PM
