View Poll Results: Which came first?
Wheels first, then coils 18 29.51%
Wheels and coils at the same time 15 24.59%
Coils first, then wheels 28 45.90%
Voters: 61. You may not vote on this poll
Old 07-02-2014, 11:34 AM   #1
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
New wheels or suspension first?
For those who got their wheels, did you get suspension done before, with, or after new wheels?
Cliu91 is offline   Reply With Quote
Old 07-02-2014, 11:46 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
Suspension, then wheels.
In close succession if you can afford it.
Don't forget a good alignment so you don't ruin your new tires.
Old 07-02-2014, 11:50 AM   #3
Letty Ortiz
DASSIT
Drives: 2014 GBS mafia
suspension before wheels always.
now if you're talking about getting cheap Taiwanese suspension then do wheels first because that will delay you ruining the ride and handling of the car
Letty Ortiz is offline   Reply With Quote
Old 07-02-2014, 11:54 AM   #4
Cliu91
Cliuless
Cliu91's Avatar
Why in close succession? Is there a specific reason?
I don't want to cheap out, so for both suspension and wheels I'm probably going to budget around 5.5k?
I don't have much knowledge on coils, but I'm told KW V3s are a good reliable choice. Got my eyes on a set of ADVAN TCIIIs as well.
What suspension setup are you running?
Old 07-02-2014, 12:01 PM   #5
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Don't forget to factor tires, mounting/balancing, and alignment into that number. I had my TPMS transferred from my stock wheels over to my new wheels, so my numbers may be a bit high, but here's how it panned out for me...
Suspension: $1900 (RS*R Sports-i)
Wheels: $1400 (WedsSport SA-10r)
Tires: $1100 (Michelin PSS 255/35/18)
Alignment: $100
Total: $4500
$5,500 should be plenty, assuming you install the suspension yourself, and depending on the deals you get on tires/wheels and whatever suspension you choose.
sdemo is offline   Reply With Quote
Old 07-02-2014, 12:04 PM   #6
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
TIRES then everything else.
Old 07-02-2014, 12:05 PM   #7
Reaper
Reaper's Avatar
Drives: violent
factory suspension is good enough to drastically exceed the capabilities of the stock tires.
Old 07-02-2014, 12:08 PM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
Well you are going to hate walking up to your car with a sick drop on stock sunken wheels that is the only reason lol
Me? I'm stock, I'm more into track right now. Don't want to go down the suspension rabbit hole for a while.
Old 07-02-2014, 12:22 PM   #9
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I did suspension first because I thought I wanted to keep the factory wheels. That didn't last long...
ericmpena is offline   Reply With Quote
Old 07-02-2014, 12:33 PM   #10
ModBargains.com
ModBargains.com's Avatar
Exactly what I would have said. If you absolutely have to do it separately, do suspension first, then wheels second.
ModBargains.com is offline   Reply With Quote
Old 07-02-2014, 12:35 PM   #11
husker741
Tires: $1100 (Bridgestone PSS 255/35/18)
Alignment: $100
Total: $4500
Since when did Bridgestone make Pilot Super Sports?
husker741 is offline   Reply With Quote
Old 07-02-2014, 12:47 PM   #12
Trettiosjuan
Drives: GT86
Get some lighter wheels 17" and a good not to harsh tire (PSS), and realize the stock suspension is excellent when you actually drive the car. Too many people confuse good handling with a slammed feel... and looks...
Trettiosjuan is offline   Reply With Quote
Old 07-02-2014, 01:01 PM   #13
sdemo
sdemo's Avatar
I had icea tea this morning instead of coffee; bite me.
Old 07-02-2014, 01:30 PM   #14
Goya
Goya's Avatar
Drives: 2013 SWP BRZ
suspension first since lowering the car will obviously change your clearance for wheels/tires. So once its lower, you can get a better idea of what size/offset wheels and tires would be good.
Goya is offline   Reply With Quote
Noob asking about wheels and suspension Arsenio3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-13-2014 11:06 AM
+1 wheels, stock suspension? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-15-2013 08:05 PM
Perfect Wheels for Stock Suspension pcamaliga Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-12-2013 02:36 PM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
Not modding - wheels and suspension available Z86 AUSTRALIA 0 10-08-2012 09:48 PM
