Old 05-11-2013, 08:50 PM   #1
pcamaliga
Drives: 2013 Scion Frs Raven
Perfect Wheels for Stock Suspension
Anybody here has pictures of wheels on stock suspension that will fill the wheel gap. Im considering Rota Grids but i dont know what size of wheels and tires that will look good on my FRS. Thanks
pcamaliga is offline   Reply With Quote
Old 05-11-2013, 09:00 PM   #2
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
You'll never completely get rid of the gap with wheels.
You will have to get some lowering springs or coilovers depending on your budget.
gatorbushmen is offline   Reply With Quote
Old 05-11-2013, 09:02 PM   #3
pcamaliga
Thanks for the info. But what can you suggest what wheel size and tire size that will look good on stock suspension?
Old 05-11-2013, 09:40 PM   #4
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
No matter what size wheels you get, it is best to keep the overall diameter (wheels+tires) the same as stock. If you go with wheels+tires with larger overall diameter to fill the wheel well, it'll make your speedometer reading incorrect and can hurt fuel economy. It'll also look donked and less like a sports car. I believe this car is on stock suspension with wheels that fill the gap (no offense to this owner; we all have different tastes):
(From http://www.ft86club.com/forums/showthread.php?p=591667)
If you're concerned about filling the wheel well, I would lower your car and keep overall diameter close to the same as stock.
Old 05-12-2013, 02:36 PM   #5
g0lden
Drives: 2013 Scion FR-S Argento
You will be happy to stay with the same diameter tire as stock. Eibach sportline springs should bring the car down quite a bit with minimal wheel gap, but coilovers are going to be needed to close it all the way and tuck the tires if you are trying to achieve that look.
I'm about to make my purchase for some BC coilovers extreme low, and the XXR 527 18x8.75 +35 on 225/40/R18.
g0lden is offline   Reply With Quote
WTB: stock suspension IloveBaldEagles Brakes, Suspension, Chassis 5 02-02-2013 04:08 AM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
WTB Stock FR-S Suspension TheSt|G Brakes, Suspension, Chassis 5 12-12-2012 08:37 PM
Not modding - wheels and suspension available Z86 AUSTRALIA 0 10-08-2012 09:48 PM
Perfect Circle Autosport Specializes In Team Dynamics Wheels Perfect Circle Autosport Wheels and Tires 17 05-19-2012 06:09 PM
