Old 07-02-2014, 01:08 AM   #1
Vex
Can't seem to swap maps Ecutek
Hi all,
I watched the Tuner do it but I can't seem to get it done. I've got a map without launch control, and one with it.
I turn the car to AC, and press on the rear defogger button but it doesn't seem to do anything, whereas for the tuner it made the Check engine light flash to indicate the map.
Am I missing something?
Vex is offline   Reply With Quote
Old 07-02-2014, 11:42 AM   #2
dp1
driving smoother faster
Drives: Sold
Usually you pull back on cruise control (pull towards yourself) and hold until RPMs go to 1k solid, indicating map1, then push up/down cruise control to change maps, then pull again to exit. On restart, map goes back to map1.
dp1 is offline   Reply With Quote
Old 07-02-2014, 11:53 AM   #3
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
EcuTek map switch instructions using rear defogger button:
Ignition on, engine off:
The driver can switch maps by turning on the rear window defogger switch while holding the accelerator to the floor. Every time you do this, the map increases by 1. After map 4, it goes back to map 1.
The check engine light will flash to indicate which mode has been set: One flash for map 1, two flashes for map 2, three flashes for map 3, etc.
Then start the car and drive!
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 07-02-2014, 05:57 PM   #4
Vex
- Bob
That's it! I wasn't pressing the accelerator.
Thanks
Swap from 2013 to 2014 not recognizing maps function Aarontalks Electronics | Audio | NAV | Infotainment 5 09-07-2014 08:27 PM
EcuTek ProECU PI/DI Maps Added EcuTek Software Tuning 1 12-22-2013 10:23 AM
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
EcuTek Gurus - questions about RaceRom feature maps RehabJeff86 Software Tuning 8 09-09-2013 02:22 PM
