Old 06-26-2014, 03:33 PM   #1
Aarontalks
Drives: 2013 FRS
Swap from 2013 to 2014 not recognizing maps function
Purchased a 2014 bespoke headunit from someone here on the forum. Install was pretty straight forward except for their being two unused slots on the back of the head unit. I also get the error "bespoke premium audio is not installed, please contact a scion dealer for upgrade details". Everything else works flawless. Thoughts?
Aarontalks is offline   Reply With Quote
Old 06-26-2014, 04:12 PM   #2
jonzhuxD
Drives: Ultramarine FR-S
Does aha radio show up as an option?
Double check the connections to the bespoke unit (I think there were two connections from the main HU to the bespoke addon unit below it)
jonzhuxD is offline   Reply With Quote
Old 06-26-2014, 11:16 PM   #3
Aarontalks
Drives: 2013 FRS
Does not aha as an option. I'll double check the wiring of those spots on the PT296-00142 unit and make sure it has 2 going into it along with the one going out split into the headunit. I'll take a picture too. Any picture someone else has or a diagram would be great. Thanks.
Old 06-27-2014, 12:34 AM   #4
Aarontalks
Drives: 2013 FRS
Aha! With some help I got it. Just needed to reboot it
Old 07-19-2014, 08:22 PM   #5
athgaurd
Drives: 2014 scion 10 series tc
How?
How did you reboot it? I just did the same thing and got the bespoke from someone else and I cannot get it to work no matter how many times I've turned the car off and then completely back on unplugged the whole thing and replugged it in and it still tells me it isn't installed.
athgaurd is offline   Reply With Quote
Old 09-07-2014, 08:27 PM   #6
invzabomaster
invzabomaster's Avatar
This!!!!!!
invzabomaster is offline   Reply With Quote
car swap day, tomorrow 5/4/2014 (Sun) 11:00AM BRZPDX Northwest 16 05-06-2014 01:54 PM
Invidia Over Pipe Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Engine, Exhaust, Bolt-Ons 1 02-25-2014 12:27 PM
APR Front Bumper Canards Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Exterior Parts - The Rest 0 01-14-2014 11:17 AM
GTSpec Rear Subframe Reinforcement Panels Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Brakes, Suspension, Chassis 0 01-08-2014 12:32 PM
Injector Dynamics Fuel Injectors 1300cc Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 RallySport Direct Engine, Exhaust, Bolt-Ons 0 01-07-2014 12:13 PM
