Old 07-01-2014, 04:34 PM   #1
jdubz13frs
jdubz13frs's Avatar
Drives: 2013 Scion FR-S 6MT
Unichip throwing p0102 code ??
Hello all,
Lest week my FR-S w/ unichip (also AFE CAI & DC cat-back) started stalling at red lights. CEL comes on, read code p0102 (MAF low voltage). Cleared, went fine for a little while. Stalled again at another light. Didn't clear code. Then, it starts misfiring/stuttering during acceleration. No flashing CEL, but enough to feel. After, car would not accelerate past 50% throttle. I could push the pedal down fine, but would not accelerate any harder than at 50% throttle. I unhooked Unichip, everything is fine. Any ideas? I hate to have this $450 chip sitting there doing nothing.... but I'd rather have a drivable car...
Any input is appreciated.
jdubz13frs is offline   Reply With Quote
Old 07-01-2014, 04:53 PM   #2
steve99
Originally Posted by jdubz13frs View Post
Hello all,
Don't know jack sH$t about uni-chips but check all wiring and connectors make sure its got a solid earth/ground connection and +12v.
If it runs fine without uni-chip connected then its unlikely to be MAF sensor fault , dirty or due to your intake mods.
sounds like uni-chip stuffed, incorrect TUNE MAP loaded/corrupted or wiring/connector problems.
The 50% throttle will be ECU in limp home mode due MAF (Mass Air Flow) sensor input out of range its the one in the intake tube.
Sell it and buy an Open Flash Tablet or similar then flash map directly to ECU = less problems.
see here different cel code but potentially same issue "connections", run a dedicated 12V and ground feed to unichip
http://www.ft86club.com/forums/showt...hlight=unichip
jdubz13frs (07-01-2014)
Old 07-01-2014, 05:03 PM   #3
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I would contact whomever you bought it from and see if they have any suggestions. I had similar problems. Eventually I modified the wiring harness giving it dedicated 12V and ground connections. After that it worked perfectly.
The Following User Says Thank You to neutron256 For This Useful Post:
Old 07-10-2014, 03:27 PM   #4
nakamur21
Drives: 2013 BRZ limited
I had the same problem in the winter. My car + unichip was awesome for about 5000+ miles, but then started stalling when coming to a stop. I removed the unichip, and everything ran perfect. A close inspection of all the connections and grounds revealed no corrosion or other connectivity problems. I really have no idea what the source of the problem is, but I haven't had the unichip back on since.
I might give it another try this summer, but we'll see. I've moved on to suspension mods, and am learning that the real performance gains with this car are all in the handling department.
nakamur21 is offline   Reply With Quote
unichip p0172 engine code bvelna Software Tuning 16 08-13-2016 08:45 AM
P0102, P0113, P2096 Engine code Oburn Engine, Exhaust, Transmission 24 09-22-2014 04:30 PM
Car wont stay running for more than a second - P0102 & P0198 STS-V Engine, Exhaust, Transmission 13 06-23-2014 01:37 PM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 01:09 PM
Throwing around an idea DrDuquette BRZ First-Gen (2012+) — General Topics 18 08-04-2012 08:27 AM
