Old 03-16-2013, 07:01 PM   #1
Ingeberger
Ingeberger's Avatar
Drives: 2013 Scion Fr-S
Unichip Error Code
Hi Jack or anyone who can offer some guidance.
I installed my unichip device last week and the check engine light came on and the traction control light was constant. I uninstalled the device and cleared the codes and went on with my way. I re-installed it this weekend and once again the check engine light is on and the traction control is constant. We scanned the ECU and the code that popped up was P0113, having to do with the air intake. I have read through the instructions diligently several times and everything is hooked up correctly.
Any suggestions?
Ingeberger is offline   Reply With Quote
Old 03-16-2013, 07:05 PM   #2
jflogerzi
jflogerzi's Avatar
I have not worked with Unichip, but are you running an aftermarket Intake? What tune are you using? Maybe you are using a tune that is geared for more airflow and a different MAF ratio so you could be running to lean? (I am very new to this stuff so take my questions for what they are worth) Just trying to provide you with ideas.
Old 03-16-2013, 07:08 PM   #3
Ingeberger
Ingeberger's Avatar
I'm running the Drop in Filter map and the Berk muffler delete. I appreciate the input though, I look into what you've noted.
Old 03-16-2013, 07:15 PM   #4
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
pm sent
Unichip Jack is offline   Reply With Quote
Old 03-16-2013, 07:18 PM   #5
jflogerzi
jflogerzi's Avatar
Hum looks like everything is in line. When you put the drop in, did you manage to get housing cover for the filter all the way back on? People have said it can be a pain to get back on. Anyways the vendor has seen your post so you should be taken care of. GL and I hope you get things sorted. BE sure to post the issue so others can learn.
Old 12-29-2013, 01:09 PM   #6
irvin1958
irvin1958's Avatar
Drives: '14 FR-S, Auto,Uni,Greddy,Perrin
Me too!
I am running a Unichip with Greddy intake, high-flow cat, Perrin Resonated exhaust. Chip was tuned for these. I ran it in the "Agressive" mode, position 1 for about two weeks and no issues. I flipped it over to the other position"0" when I refueled with the same level 91 Octane. After about half a tank of fuel, I have a check engine light and constant VSC amber light.
Any one?
Thanks.
irvin1958 is offline   Reply With Quote
TechStream Error Code B14A1 developer Issues | Warranty | Recalls / TSB 13 10-08-2018 07:22 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
Paperwork error Rob_g Scion FR-S / Toyota 86 GT86 General Forum 4 05-24-2012 11:38 PM
Driver error Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 5 07-14-2010 07:25 PM
