Old 07-01-2014, 03:33 PM   #1
Allaskew
Drives: Scion FRS
Differential swap kit?
Anybody have insight on the rumor of a differential swap kit for the FRS? I recently heard that there was something floating around out there for a Ford 8.8 diff. If you have, please shoot me a PM. Thanks.
Allaskew is offline   Reply With Quote
Old 07-01-2014, 03:56 PM   #2
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Ford 8.8 diff comes from @FullBlown
http://fullblownmotorsports.com/full...iff-conversion
JohnJuan is offline   Reply With Quote
Old 07-01-2014, 05:26 PM   #3
Allaskew
Drives: Scion FRS
Originally Posted by JohnJuan View Post
I appreciate that. But I have their LS swap kit and I'm not very happy with it. So I'd be better off coming up with something on my own.
Old 07-01-2014, 05:41 PM   #4
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
$6000 AND you have to pay EXTRA for the driveshaft shown in the pics? Good god!
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following 2 Users Say Thank You to phobos512 For This Useful Post:
FRSBRZGT86FAN (01-20-2016), hmong337 (07-02-2014)
Old 07-01-2014, 06:04 PM   #5
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Since when did fullblown make an ls swap kit?
The Following User Says Thank You to Reaper For This Useful Post:
slicktop (07-01-2014)
Old 07-01-2014, 07:09 PM   #6
Mikem53
Drives: FR-S 6MT
6k for a diff? That's insane..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Old 07-01-2014, 07:16 PM   #7
Allaskew
Drives: Scion FRS
My bad. Weapons Grade is the swap kit.
Old 07-01-2014, 07:19 PM   #8
Allaskew
Drives: Scion FRS
It is insane. Supposedly, a Lexus IS diff has been used.
The Following User Says Thank You to Allaskew For This Useful Post:
Mikem53 (07-01-2014)
Old 07-01-2014, 07:35 PM   #9
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
That kit comes with 1000hp rated axels, and a 1000hp rated alumninum driveshaft. you have to pay extra for the carbon fiber (understandable). I agree they should advertise it with the aluminum driveshaft shown though.
thats about $2,000 dollars in axels and driveshaft. Not a horrible deal.
But I am not running anything close to needing 1000hp axels and driveshaft.
The Following User Says Thank You to tahdizzle For This Useful Post:
strat61caster (07-01-2014)
Old 07-01-2014, 10:42 PM   #10
Reaper
Reaper's Avatar
Drives: violent
I'm guessing the people calling this expensive have never swapped major drivetrain components before. Its a good deal. A lot of machining and custom parts in that kit. See above.
Old 07-02-2014, 08:29 AM   #11
Mikem53
Drives: FR-S 6MT
I've swapped plenty in the past and never for that much.
Limited choices make for a high price.. I get that.. But that's still
A ridiculous price to pay for a diff..
Old 07-02-2014, 10:15 AM   #12
Reaper
Reaper's Avatar
Drives: violent
Thats not the price for the diff weve already said that.
Old 07-04-2014, 09:49 AM   #13
NOHOME
Drives: RAVEN
That is a ton of money for a rear end . I do appreciate the fact that it is not a high volume item, but still.
The key item, and what I like most about the kit is the elegance of the billet rear cover. Because of the miracles of CNC machining and the availability of inexpensive scan tools, IF they are willing to put the time in, anyone with a scanner and Solidworks skills can create a very similar kit for a lot less. (As long as their time if free)
And maybe use the Cobra 8.8 so as to score an alloy differential case. Buy a diff with a locker for about $200, tons of them around, if not both the locker and the rebuild kits can be bought for about $900
If I wanted to doodle the rear cover/mount, I would spend a couple of hundred dollars to have it 3D printed just to make sure that it all fit before I spent the money on the block of alloy and CNC mill time.
The Driveshaft shop makes IRS axles to order. 1000 HP claim might be nice marketing claim, but overkill for 99.99% of the planet. How the hell am I going to validate that claim anyways?
Tons of drive-shaft shops out there that will sort that bit out for you. Carbon is cute, but you would never measure any difference for the $$$. Drive-shafts that will do the job are about $500 from most suppliers.
The Miata V8 conversion crowd does the rear end conversion for their swaps for about $2500-$3000 including the diff, (that includes a vendor profit margin) so they would have a meltdown at this price. I did mine for $1700 with axles from the driveshaft shop.
The above all said, it is a good thing to see V8 conversion vendors for the Twins, this is something that has worked well in the Miata world and I hope does as well in the FRS/BRZ genre.
NOHOME is offline   Reply With Quote
Old 01-18-2016, 01:37 PM   #14
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Sell the "FBM Billet Aluminum Rear Cover w/hardware and mounting brackets" separate.
Fenix is offline   Reply With Quote
DIY - Differential and Ring & Pinion Swap Dustin DIY (Do-It-Yourself) Guides 126 07-01-2019 10:29 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Anyone have a differential pop yet? slicktop Engine, Exhaust, Transmission 6 02-26-2014 08:22 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
Eww rear differential goo LeeMaster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 04-10-2013 09:17 PM
