Old 07-01-2014, 11:54 AM   #1
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Halo headlights install
I am wondering how hard is it to install halo led with led projectors and bake the housing black. I can either do it myself cheaper or go to a shop 4 hours away to do it for me for $450. If I mess up though, I will need new headlights
Sent from my SGH-T989 using Tapatalk
904FRSlow is offline   Reply With Quote
Old 07-01-2014, 11:56 AM   #2
904FRSlow
904FRSlow's Avatar
Size:  13.3 KB something like this except with one halo on each side
Old 07-01-2014, 12:05 PM   #3
sshole
It's not hard if you're a professional or avid DIYer.
It's very hard if you're not.
sshole is offline   Reply With Quote
Old 07-01-2014, 02:40 PM   #4
Chimera
Drives: FRS
I did it DIY. One head light has a cat hair in it, which only I ever notice because I did it, otherwise it turned out perfect. 450 I'd say is pretty fair given the amount of work. depends on how much your time is worth and whether you enjoy DIY projects. I do, so I DIY, if I didn't I'd pay to have it done.
Old 07-01-2014, 03:19 PM   #5
904FRSlow
904FRSlow's Avatar
Thank you for the input. I think I will let them do it then.
Old 07-01-2014, 10:50 PM   #6
904FRSlow
904FRSlow's Avatar
Found out they can mail me a completed set and I just have to install. Is the wiring tricky for headlights or should i be fine?
Old 07-02-2014, 10:31 AM   #7
sshole
If you can't do the mechanical part of this job (pulling headlights apart), don't try to do the electrical part of this job (wiring new accessories). You're gonna have a bad time.
Old 07-02-2014, 03:17 PM   #8
904FRSlow
904FRSlow's Avatar
I can probably take the headlights out after watching a few videos. Not sure if it will be plug and play or if I will have to mess with things. I will ask them over the phone though
Old 07-02-2014, 03:27 PM   #9
kALMIGHTY
Drives: TRD Ultramarine '13
If you're going to spend that much money on installing a halo on the stock headlights, might as well just spend the money on buying new aftermarket headlights.
Old 07-02-2014, 03:29 PM   #10
904FRSlow
904FRSlow's Avatar
I don't really like the other options besides spec-d. The only one i have seen with halos is spyder and those are close to $700 and are crappy quality. I really like the halos i have seen though
Old 07-02-2014, 03:45 PM   #11
sshole
Seriously, if you don't already know that adding in non-standard lights to your vehicle will require additional wiring, this isn't the project for you.
I'm not trying to be mean or condescending. I'm trying to help you by not having you burn your car down due to electrical fire.
The Following User Says Thank You to sshole For This Useful Post:
lightdir (07-06-2014)
DIY - Diode Dynamics HID install on WinJet/Spyder Headlights FT-86 SpeedFactory DIY (Do-It-Yourself) Guides 0 02-21-2014 09:57 AM
Spyder LED Headlights w/ Halo Ring. Black Housing. connor_lol Cosmetic Modification (Interior/Exterior/Lighting) 4 01-26-2014 09:58 PM
Halo 4 players? DarrenDriven Off-Topic Lounge [WARNING: NO POLITICS] 32 12-12-2012 12:32 PM
Problem Headlights after HID Install imravenit Cosmetic Modification (Interior/Exterior/Lighting) 2 09-30-2012 08:18 AM
*** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** zAnSh1n Cosmetic Modification (Interior/Exterior/Lighting) 21 04-04-2012 04:41 PM
