Drives: 2013 FR-S, 1990 Miata
A/C pump kicking on and off after cold start?
Hey guys I am not quite sure if this is a problem but it is definitely strange to me since I have never had a car do this before. Anyways here is precisely what happens.
1. Start car in the morning (55 degrees ish outside) 2. While idling the A/C pump harshly kicks on and then off at least 4-5 times 3. My A/C is turned off and it was turned off before the car was shut off last. Also the defog is turned off too. (not sure if the A/C pump kicks on for that or not..) 4. I sit there confused.. ![]() I dont know if this is normal or not but I sure would like to know. I know this kind of behaviour from other cars I have owned when the A/C isnt charged and you try and turn it on and the pump just kicks on and off because it doesnt have enough pressure but this seems like a totally different situation.. Also my A/C does work and blow cold (although it could be colder..) Any help would be great thanks guys!
The defroster uses the A/C pump, turn off the defroster and the A/C won't cycle, but then foggy windows.
It does this to dehumidify the air being blown across the windshield to reduce the fog quicker. Edit: if the defrost blower is off and the rear window defrost is off as well then the a/c shouldn't be turning on, that'd be a dealer question. |
Yea I know the concept of the defrost and that was also off. BUT I did discover something this morning. It happens only when I have the fan turned on. Everything else is off and it is not set to recirculate. But when I turn the fan on is when it starts kicking on and off (which I had accidentally left my fan on yesterday when I shut my car off). But yea this is just strange. I guess ill try and stop by the dealer.. bleh They never like to do anything so its probably "normal" according to them..
| Disable high Rev cold start | Raven604 | Engine, Exhaust, Transmission | 408 | 03-28-2022 10:27 AM |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Loud misfires upon cold start | connorlug | Issues | Warranty | Recalls / TSB | 42 | 03-31-2016 04:43 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
