Drives: Toyota 4runner Sport Edition
Rce t2 or kW v3s what else is needed
I'm a complete noob when it comes to suspension setups. I'm looking for a good set of coilovers for mostly street use with some auto cross and possibly track days. If I went with t2s or v3s what supporting mods would I need. Obviously alignment but as far as control arms, top hats camber bolts etc what all is needed/recommended?
#2 | |
I'm currently using the V3's and Whiteline LCA's, Whiteline Toe Arms. As far as what's needed? Just the control arms for adjusting rear camber. If you're really hardcore, you can get the bushings on the upper control arms to control camber, but the labor is double the cost of control arms. That's pretty much where I would start. Then feel how your car drives and go from there. From then you can decide on sway bars, bushings, strut bars, underbody bracing, etc. |
| The Following User Says Thank You to FR-S Matt For This Useful Post: | Colpup (06-25-2014) |
Lacking brains
Drives: frz
I was running just the kwv3 on stock tops and no lca or other suspension mods.
Went great for autox/hpde and the street comfort is tits But i didnt go very low. So rear camber isnt too bad. |
#4 | |
Drives: 2015 WRX
Top hats are not needed but are always nice for that sexy castor (raceseng is pricey but ohhh so worth it). You wont need camber bolts because the top strut holes are slotted. |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
| The Following 4 Users Say Thank You to fooddude For This Useful Post: |
^^^already taken care of haha
As of right now, although I change my mind by the minute, I'm leaning towards v3s with probably whiteline lca's with whiteline toe arms. I've wanted the t2's for a while now but with some of the groupbuys it looks like v3's are quite a bit cheaper. Now to decide if headers and a tune come before suspension. Sent from my HTC6525LVW using Tapatalk |
Drives:
| Anything else needed? | Ymerej | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 02-03-2014 09:33 PM |
| Help Needed | Ocho Seis | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 02-02-2014 02:00 AM |
| HELP NEEDED!!!! | sklimo | Issues | Warranty | Recalls / TSB | 26 | 06-14-2013 11:48 AM |
| LOC Needed? | delusional | Electronics | Audio | NAV | Infotainment | 2 | 04-09-2013 09:24 AM |
| Lug Nut Help Needed | USMC -FRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 01-17-2013 10:06 PM |
