Old 06-22-2014, 03:23 PM   #1
SimplePortal
Drives: Hot Lava
Sound deadening rear seat
Has anyone try putting a layer of MLV inside the back seat? Not talking about the under the rear seat but inside the seat fabric to help block off noise from the trunk. Would it make any noticeable sound difference?
SimplePortal is offline   Reply With Quote
Old 06-22-2014, 05:54 PM   #2
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
I actually did this a few days ago. It is very easy to do. I installed deadener in the whole trunk as well, so I can't answer if doing only the rear seat will make much of a difference.
Terrapin77 is offline   Reply With Quote
Old 06-22-2014, 06:01 PM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Not to jack your thread OP, but @Terrapin77, how did you unfasten the fabric on the back of the rear seat? I was going to do this but was afraid I would screw it up.
BirdTRD is offline   Reply With Quote
Old 06-22-2014, 06:25 PM   #4
Vinnito1
Drives: 2014 brz
I've done the rear seat as well. I notice a slight difference in noise, but not much. Every bit helps
Vinnito1 is offline   Reply With Quote
Old 06-22-2014, 09:22 PM   #5
troek
troek's Avatar
Drives: 2012 Toyota 86
i believe the most effective way is to layer the rear deck, the rear seat back, and below the rear seat, creating a whole boundry from the muffler. ive done under the seat, and the rear speaker deck, and it was noticeable. i still have to do the back of the seat but i ran out of sound deadner. its noticebe when i have the seat folded down or up, so im sure a layer of sound deadening on the seat back can only help further.
Old 06-22-2014, 09:24 PM   #6
troek
troek's Avatar
the clips around the side edges just pup up with a little force, and then slide it in from the side, poke some holes through the mlv for the clips, then button it back down.
Old 06-22-2014, 10:19 PM   #7
Terrapin77
Terrapin77's Avatar
1. Pop out the 4 black push pin clips
2. Unhook the long clip at the bottom of the seat. It runs almost the length of the seat. Start on one side and work your way to the other side.
3. Each side is held in by 3 clips. While pulling on the them, use a small flat head screwdriver to pop them out.
4. Cut MLV to fit the seat.
5. Cuts holes in MLV to reinsert the clips. Dont' forget to cut the holes for the seat latches.
6. Use contact cement or spray adhesive to secure MLV to the seat frame.
7. Put seat back together and install in car.
Old 06-24-2014, 04:26 AM   #8
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I've done almost all my car with cascade audio products. MLV and direct sound matting and Vmax. I can say as I did it in steps that the mass majority of road noise blocking came from doing the cavities below two rear seats. That audibly was most noticeable improvement.
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 12:51 PM
Where can I get MLV / thinsate? -sound deadening luv85 Australia Classifieds 1 02-10-2014 10:50 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 01:36 AM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 02:08 PM
Sound deadening yomchi1989 AUSTRALIA 9 12-27-2012 09:09 PM
