Old 12-27-2012, 02:54 AM   #1
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Arrow Sound deadening
Can anyone comment on the effectiveness of Dynomat sound deadening? Does it really make a difference to "punchier" bass and better sound quality?
I've been quoted $300 inc. installation.
yomchi1989 is offline   Reply With Quote
Old 12-27-2012, 03:06 AM   #2
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
It does make some difference. Take a look at brownbread and fatmat too.
ZC6BRZ is offline   Reply With Quote
Old 12-27-2012, 10:13 AM   #3
wrmathis
Drives: no car :(
And raammat is also another good alternative
2013 Scion FR-S Ultramarine blue
2006 Tacoma TRD O/R S/C 6spd (has a few mods)
wrmathis is offline   Reply With Quote
Old 12-27-2012, 11:34 AM   #4
wheelhaus
wheelhaus's Avatar
as well as www.secondskinaudio.com awesome products.
wheelhaus is offline   Reply With Quote
Old 12-27-2012, 01:01 PM   #5
mashal
DADA
mashal's Avatar
Drives: 2013
300$ for dynamat installed is very good, dynamat is on the top of the list, it's not cheap.
I have looked at other products and most of them suck .
mashal is offline   Reply With Quote
Old 12-27-2012, 02:53 PM   #6
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
From my experience i stay away from any tar related products, especially tar Mats. but thats just me.
What your trying to ultimately achieve is altering how vibration travels to fit your needs. Which is different than just dampening sound. If you want to get cleaner sounds from your audio equipment, then a mat will do just fine. If you want better acoustics for your audio environment then id suggest going for a spray.
Foams and Insulations are too bulky, to heavy, and only really absorb sound waves, not necessarily absorb vibration.
WingsofWar is offline   Reply With Quote
Old 12-27-2012, 04:01 PM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what the clown said
first you have to establish what you want
sound deadning and vibration control addresses specific issues but generally they are secondary to simply adding moar powa (amp)
what are your goals?
Old 12-27-2012, 05:12 PM   #8
yomchi1989
n00b
I don't really have any goals. I just want the best sound from my gear and punchy bass. I have a sealed sub getting installed. The man told me that Dynomat will make a big difference to quality.
Old 12-27-2012, 05:22 PM   #9
wheelhaus
wheelhaus's Avatar
To more specifically answer your question, yes. A given speaker (or "driver") can only be as good as it's signal quality, amplification, and acoustics. Sound deadening can very much affect acoustics. Compare listening to a fantastic home speaker system in an empty subway, or in a nice, quiet living room... Huge difference.
Most of the vibration absorbing materials used today are called "CLD" (Constrained Layer Damper). They're a super sticky layer of butyl backed by a thin malleable layer of aluminum. Good quality materials will stick extremely well to damn near anything, as well as forming to curves and ridges. Closed cell foam layers and vinyl materials all have their purpose, and if used in the correct applications/locations your car can be made to sound as dead quiet as a nice luxury car.
Most people end up adding 2-6 sq ft CLD to each door skin/structure with a dense foam pad or acoustic tile on the skin behind the door speakers, and then 4-12 sq ft to the trunk area if vibrations are a problem. At minimum, you'd ideally want to add some CLD to any area of the body or interior panel that vibrates or resonates. Small patches usually do the trick, don't need to cover everything.
See if you can get an explanation of what they're doing, because "installing Dynamat in the doors" leaves a lot of gray area...
Old 12-27-2012, 06:59 PM   #10
yomchi1989
n00b
They said they put an inner and outer skin to the doors...
Old 12-28-2012, 09:57 AM   #11
bobpuffer
bobpuffer's Avatar
Drives: FR-S Hotlava 6-speed
Operating in an area where I knew less than nothing I decided to research who did and found Don at Sounddeadenershowdown to be highly regarded as an expert. Contacted him and he provided a listing of all the materials I'd need as well as detailed instructions for installing. Have never been happier -- my car sounds like I'm inside a refrigerator, only with a headunit going -- don't hear another thing.
bobpuffer is offline   Reply With Quote
Old 12-28-2012, 12:56 PM   #12
Joeprelude
Joeprelude's Avatar
Drives: 2013 FRS, 2002 WRX Wagon
Yeah Don helped me with my 73 Charger Build. Basically felt like riding in a MB after the install. Although we added alot of weight (about 150lbs of Closed Cell foam, CLD tiles and Mass loaded vinyl) to my Charger, you could hear the exhaust drone of a built 400 Big Block, but that was about it, no road noise, engine noise and no rattles from the car or audio system. the audio in that car was one of the best systems i ever installed and the before and after of the sound deadening was crazy. The FRS doesn't need as much deadening as my Charger did, but the way they explain to figure out how much and where to put cld changed the way ive done audio installs for the past 5 years.
Joeprelude is offline   Reply With Quote
Old 12-28-2012, 03:22 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
Would love to see details of what your installation entailed and how much it set you back.
Old 12-28-2012, 03:30 PM   #14
mashal
DADA
mashal's Avatar
Drives: 2013
I contacted don twice , never got a reply 😢
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 12:51 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 01:36 AM
Sound deadening yomchi1989 AUSTRALIA 9 12-27-2012 09:09 PM
Best sound BAE Engine, Exhaust, Transmission 4 09-30-2012 09:30 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
