Old 06-19-2014, 04:23 PM   #1
CokeSlap
Drives: 2014 Monogram FRS Whiteout
Tow Hook Cutout diagram
For all of those that are using a license plate relocator here is the diagram that raceseng uses for their cutouts.
I haven't been able to do the drilling yet but I figured this was a good place to start for all of those that want their relocator to look a bit cleaner and were afraid to just dive straight into cutting.
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
The Following 11 Users Say Thank You to CokeSlap For This Useful Post:
AllStar0419 (06-20-2014), Ammunition (06-22-2014), cpafford (10-23-2014), D_Thissen (06-20-2014), FR-SBPK93 (06-20-2014), iketeru (06-19-2014), JonAvalon (06-20-2014), Jrryjms07 (06-19-2014), phobos512 (06-20-2014), STV3 (06-19-2014), WhiteFRS69 (06-22-2014)
Old 06-20-2014, 12:06 AM   #2
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
This should be a sticky in the diy section. I wish i would've had this when I did mine instead of having to dremel it out over and over until it fit.
Sent from my Galaxy S4 using Tapatalk
AllStar0419 is offline   Reply With Quote
Old 06-20-2014, 12:11 AM   #3
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Not gonna lie I did the old cardboard cut out trick and just filed it up to size. Mine came out great but this would have saved me a good hour or so of guess and check. Plus I'm a measure 4 times think about cutting, measure again then cut below my lines anyway to be safe kind of guy lol.
FRSfan111 is offline   Reply With Quote
Old 06-20-2014, 12:15 AM   #4
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Thank you!!!! I just may finally try this out
JonAvalon is offline   Reply With Quote
Old 06-20-2014, 01:36 AM   #5
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I was lucky and found someone local that had already done it, so just used his as a template
Great find though, would be useful in the DIY section.
Jyn is offline   Reply With Quote
Old 06-20-2014, 10:32 AM   #6
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Make sure you select "Actual Size" when you print this - Acrobat defaults to "Fit" and depending on your printer this could shrink/enlarge the template and screw you up. Also, remember to use a bunch of painter's tape over the area you drill so that the paint doesn't get torn up in the area that is left behind.
For folks who have done this, how much room is left around the tow hook shaft? Is it enough to install a rubber grommet?
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-22-2014, 05:43 PM   #7
phobos512
phobos512's Avatar
Used this today. Found it a little big in the horizontal and a little tight in the vertical. It's making a 1" hole on the profile of the curve of the bumper but it's a little too ellipsoid. I also couldn't find a grommet that would fit at my local Lowe's so if anyone could share what they used I'd appreciate it.
Old 06-22-2014, 07:06 PM   #8
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
Thank you for this!
Ammunition is offline   Reply With Quote
Electric Exhaust Cutout = Loud as %$#@ M-17 Engine, Exhaust, Transmission 44 05-05-2019 06:59 PM
electric cutout davebrus Electronics | Audio | NAV | Infotainment 0 03-21-2014 01:26 PM
2 SVC+ 2 DVC WIRING DIAGRAM PineappleFriedRice Electronics | Audio | NAV | Infotainment 8 03-03-2014 01:12 PM
FS: Red with cutout tail light vinyl film from bluebatmobile $30 tracerit Southern California 1 08-07-2013 04:36 PM
AWD FT-86 Diagram AaronCompNetSys Scion FR-S / Toyota 86 GT86 General Forum 52 11-22-2011 02:53 PM
