Old 04-07-2013, 11:07 AM   #1
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
Cheap/Crafty Oil Cooler question.
I was thinking of getting an oil cooler, however they can be a bit pricey. Transmission coolers however, are all over the place and cheap. I was wondering if it would be a good (or bad) idea to use a transmission cooler as an oil cooler. Would the transmission cooler tubing be too narrow/restrictive for oil?
Thanks.
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 04-07-2013, 11:23 AM   #2
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
This question is why a professionally engineered solution may bring more peace of mind. I dont know the answer either.
Huehuecoyotl is offline   Reply With Quote
Old 04-07-2013, 12:08 PM   #3
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Well, if the cooler is designed/capable for the same fluids, temps , pressure and flow rate then it should be ok.
When you spend the big bucks on a name brand one, you are getting someone to blame if the part fails, and you get a shiny name tag to go with it.
I personally like the Perrin one, you get the sandwich plate, really nice hoses and a/n fittings which are all anodized.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 04-07-2013, 04:09 PM   #4
Asterisked Accolade
Is there a way to discern whether or not a said trans cooler is capable of these such variables?
Old 04-07-2013, 06:32 PM   #5
Wonderbar
Driveway labs.
Wonderbar's Avatar
He'll I dunno, compare its specs with that of one of the purpose built ones.
Old 04-07-2013, 08:56 PM   #6
D1cker
Drives: B9 S4/ND2
If you're trying to spend the least possible, go buy a CX racing core, it's like $80.
D1cker is offline   Reply With Quote
Old 04-07-2013, 09:47 PM   #7
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
I wouldn't buy from them if it was one dollar!!!
WillRacer1jz is offline   Reply With Quote
Old 04-07-2013, 10:29 PM   #8
bpracer
Drives: Asphalt FR-S
I'm pretty sure a typical "round tube snaking through a field of fins" is not that efficient for their size. There is not that much real cooling surface area in those coolers.
The tube size is probably not that big either. It is probably smaller than a -10 AN fitting. I have not seen trans coolers that use anything bigger than a 1/2" (-8AN) line. That is too small and would be very restrictive.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 04-07-2013, 10:45 PM   #9
plucas
plucas's Avatar
Drives: Subaru
I can tell you first hand, do not go cheap. Cheap means you will get a cheap core and cheap manufacturing. In my opinion do it right the first time. Depending on the size you want, I can recommend something and might not be custom. If you want -12AN and a smaller size, I would recommend a C&R Part#: 41-00001
plucas is offline   Reply With Quote
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 03:40 AM
