Old 05-13-2013, 07:33 AM   #1
solma
Drives: Raven FRS
Technical question about oil cooler
Hi,
I was looking at the vastly discuss oil cooler kit and had few question about it(maybe it was already answer but did not find the answer):
- There seem to be a lot of question about pressure drop in the oil line, what exactly doing a pressure drop(if high enougth) will cause?
- What is the maximum pressure drop in the system(so the system stay stable without any adverse effect)?
Looking at Setrab oil cooler, I did not understand how the spec of the pressure drop work, here the example in question(spec from they website):
oil cooler
SLM 592-6 pressure drop 4.0-4.5
Differential / Gearbox Coolers
SLM 592-6 pressure drop 1.5
Why is the oil cooler(SLM 592-6) as two different spec(pressure drop
) depending on which menu you search for the spec(oil cooler or diff/gear cooler)? Is it because of take oil viscosity?
Thanks
solma is offline   Reply With Quote
Old 05-21-2013, 08:27 PM   #2
Dezoris
Dezoris's Avatar
Anyone want to answer this?
Old 05-21-2013, 08:47 PM   #3
Mo707
Mo707's Avatar
bump
Mo707 is offline   Reply With Quote
Old 05-22-2013, 08:21 AM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by solma View Post
Hi,
As I understand it, you need the pressure to get oil in all the places its needed throughout the motor and to get proper oil flow. If you loose that pressure, you won't get proper lubrication. That's the only one I can answer.
Old 05-22-2013, 10:02 AM   #5
OrbitalEllipses
Drives: Attitude
It's the same idea as pressure drop across an intercooler, except we're talking about oil and not compressed air.
Old 05-27-2013, 08:54 AM   #6
solma
Drives: Raven FRS
In anyways, I decide to go ahead, I currently buiding a custom oil cooler, It will be in the bumper(bumper is being modified right now), did not want to put directly in front of the current radiator for future intercooler upgrade, and wanted more airflow to cool more heat, keep the option for double thickness radiator for later.
The price+trouble is much more higher than the standard kit but I like good integration. By opening the top portion of the front grill, I will gain some new air to cool the oil.
I will be using setrab 420-10(10 row), it is spec for 170-200HP, should be enought.
We will see, hoping to have everything in 2-3 week.
I did find the minimum oil pressure needed in the service manual, and I will monitor oil pressure in the gallery to confirm that everything is within spec.
Cheap/Crafty Oil Cooler question. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 8 04-07-2013 10:45 PM
Supercharger - technical questions... diss7 Forced Induction 21 10-13-2012 08:50 AM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 03:40 AM
Technical Issues Thread hyper4mance Site Announcements / Questions / Issues 1 06-25-2012 06:26 PM
