Drives: None
My car was wobbling at start up
NOTE, MY CAR IS FI WITH A TURBO KIT
On a long hot almost 2hr drive home yesterday, my car was vibrating and wobbling really harsh on the passenger side one hour within the trip. I pulled over drove 15mph and the thing was wobbling like crazy still. Then I turned it off and cranked it back up and the car was shaking, almost like a roller coaster, on the passenger side when starting. I repeated this twice untill the third stop... On the third stop I turned it completely off and waited almost an hour, then I turned it on and it was almost driving normal until a couple minutes later, it started again. So I just drove it home slowly and left it alone for a whole day, today when turned on the engine, it sounded kind of harsh, no engine knock but harsh.. Car only has 25k miles, and 2k miles with the turbo... No cel or nothing.... Has anybody had this issue? I think my engine might detonate pretty soon. ![]() Sent from my iPad using Tapatalk |
Drives: Scion FR-S
That sounds like a misfire. Subaru has a pretty long history with misfire issues.
Sent from my Q10 |
| The Following User Says Thank You to Accurate Race Shop For This Useful Post: | Astroboy (06-14-2014) |
Drives: None
#4 | |
Drives: Scion FR-S
Sent from my Q10 |
Drives: Scion FR-S
My best advice is to take it to a place with free diagnosis and let them tell you exactly what's wrong and then you can decide if you want to fix it or if you want to pay to have it fixed.
Sent from my Q10 |
Junior
Drives: a car
Another good piece of advice, always run with a ECU code scanner in your car once you do major mods like turbo'ing an NA motor
Drives: None
your probably going to need something a bit better, like techstream you can buy dongles and software on internet for $30 and you will be able to monitor misfire counts per cylinder ect to help you track it down or just take it back to guys that did turbo tune.
#11 |
Have you contacted your tuner? Which turbo kit? How many miles boosted?
#12 | |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I feel you should contact your tuner. |
#13 |
Junior
Drives: a car
interesting, might want to invest in a way to take some logs of the ECU. Not sure specifically what that would entail, but I'm sure @jamesm would be of great assistance on that front.
#14 |
Drives: None
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 07:06 PM |
| Ugh! Car won't start :( | FRSGIRL❤ | CANADA | 53 | 05-10-2013 05:52 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 03:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
| Tad's CBS BRZ From The Start | Tad_07 | Member's Car Journals | 8 | 10-12-2012 03:19 AM |
