Old 06-14-2014, 10:30 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
My car was wobbling at start up
NOTE, MY CAR IS FI WITH A TURBO KIT
On a long hot almost 2hr drive home yesterday, my car was vibrating and wobbling really harsh on the passenger side one hour within the trip. I pulled over drove 15mph and the thing was wobbling like crazy still. Then I turned it off and cranked it back up and the car was shaking, almost like a roller coaster, on the passenger side when starting. I repeated this twice untill the third stop... On the third stop I turned it completely off and waited almost an hour, then I turned it on and it was almost driving normal until a couple minutes later, it started again. So I just drove it home slowly and left it alone for a whole day, today when turned on the engine, it sounded kind of harsh, no engine knock but harsh..
Car only has 25k miles, and 2k miles with the turbo... No cel or nothing....
Has anybody had this issue?
I think my engine might detonate pretty soon.
Astroboy is offline   Reply With Quote
Old 06-14-2014, 10:33 PM   #2
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
That sounds like a misfire. Subaru has a pretty long history with misfire issues.
Sent from my Q10
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Astroboy (06-14-2014)
Old 06-14-2014, 10:36 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
Sent from my Q10
Thanks for the response, how do you recommend I fix it and check it?
Old 06-14-2014, 10:41 PM   #4
Accurate Race Shop
Drives: Scion FR-S
That's the hard part there is a ton of things that can cause it. The most common in a fried spark plug bad distributor loose negative terminal on the battery or low compression
Sent from my Q10
Old 06-14-2014, 10:42 PM   #5
Astroboy
Astroboy's Avatar
Drives: None
Could the 92 degree heat be an issue?
Old 06-14-2014, 10:44 PM   #6
Accurate Race Shop
Drives: Scion FR-S
My best advice is to take it to a place with free diagnosis and let them tell you exactly what's wrong and then you can decide if you want to fix it or if you want to pay to have it fixed.
Sent from my Q10
The Following 2 Users Say Thank You to Accurate Race Shop For This Useful Post:
Astroboy (06-14-2014), cdrazic93 (06-14-2014)
Old 06-14-2014, 11:07 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Another good piece of advice, always run with a ECU code scanner in your car once you do major mods like turbo'ing an NA motor
Old 06-14-2014, 11:12 PM   #8
Astroboy
Astroboy's Avatar
Drives: None
I have an obdii scanner, but I never got any codes... Nor cel
Old 06-15-2014, 12:18 AM   #9
steve99
Drives: FT86
your probably going to need something a bit better, like techstream you can buy dongles and software on internet for $30 and you will be able to monitor misfire counts per cylinder ect to help you track it down or just take it back to guys that did turbo tune.
Old 06-15-2014, 12:18 AM   #10
Astroboy
Astroboy's Avatar
Drives: None
Could a 10% ethanol mixture in 93 octane be a problem?
Old 06-15-2014, 12:20 AM   #11
jflogerzi
jflogerzi's Avatar
Have you contacted your tuner? Which turbo kit? How many miles boosted?
Old 06-15-2014, 12:24 AM   #12
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Doubtful. I use 93 octane with 10% ethanol and have never had the problem you're experiencing. However, my car is stock.
I feel you should contact your tuner.
Bobblehead is offline   Reply With Quote
Old 06-15-2014, 12:24 AM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
interesting, might want to invest in a way to take some logs of the ECU. Not sure specifically what that would entail, but I'm sure @jamesm would be of great assistance on that front.
Old 06-15-2014, 02:27 AM   #14
Astroboy
Astroboy's Avatar
Drives: None
Avo, only 2k miles boosted..
Could the vibration be limp mode maybe?
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Ugh! Car won't start :( FRSGIRL❤ CANADA 53 05-10-2013 04:52 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Tad's CBS BRZ From The Start Tad_07 Member's Car Journals 8 10-12-2012 02:19 AM
