Old 06-14-2014, 05:57 PM   #1
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Ecutek noob
This is a painful thread for me to start...im usually not the noob.
I had my car tuned with ecutek before i was able to get a cable and deskey. Now that i have one that i got used im stumped. I downloaded proecu and updated everything and have coms with the ecu. Dtc code read works etc. but since i dont have a copy of my rom im not sure what to do after i querry the ecm. Im just trying to datalog and see if my racerom features are locked. Could someone point me in the right direction? I feel like my grandfather trying to use an iphone for the first time.
Old 06-14-2014, 07:28 PM   #2
DBW
Motorsports
Drives: 19BRZ PP, 16 M4
Raceroms are keyed to the dongle (tuner) that created them. Your only option for anything other then DTC and logging would be to start from scratch using a stock file.
Douglas W.
DBW is offline   Reply With Quote
Old 06-14-2014, 07:30 PM   #3
Reaper
Reaper's Avatar
Drives: violent
Still confused on logging though. Not sure what to do after dump. I'm tuping thia from mobile ao I could be wrong but pretty sure it asks me to select the rom and that's whereb I'm not sure what to do next.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-14-2014, 09:20 PM   #4
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
If your tuner doesn't mind you can ask them for an unlocked file. You will need the RaceROM upgrade to get at the custom maps if they were used though.
Otherwise you'll need to create your own file based off of one of the ROMs in the stock ROM directory. Reading the ROM on the ECU currently will not work, and EcuTek will not give that to you as they have no way of knowing if the tuner "ok'd" you to get the file. The downloaded files (rom dumps) will not be readable to you.
Xero-Limit is offline   Reply With Quote
Old 06-15-2014, 02:27 PM   #5
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Question to optain a data log from ecutec, do I need the tunner to give it to me or can I get it by myself with ecutek
Sent from my SAMSUNG-SM-G900A using Tapatalk
kombatlion is offline   Reply With Quote
Old 06-16-2014, 02:47 AM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can datalog so long as you have a ROM file. As ECUtek provides some base ROMs with the ProECU download, just add the RaceRom features to the relevant ROM and you're good to go.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
kombatlion (06-16-2014)
Old 06-16-2014, 02:25 PM   #7
Reaper
Reaper's Avatar
Drives: violent
Does it matter which rom I use for datalogging?
Old 06-16-2014, 02:38 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
No.
Old 06-16-2014, 02:39 PM   #9
Reaper
Reaper's Avatar
Drives: violent
Oh...well that solves it. Yup, noob as hell with ecutek.
Old 06-17-2014, 02:30 AM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
Just make sure you add the extra features to the ROM otherwise you'll only get the basic logging parameters. Once you add the ECUtek RaceRom patch to it, it will allow you access to all of them.
.: Stealth 86 :.
Kodename 47 DJ:
Noob Here nwolsky Software Tuning 10 06-02-2014 09:06 PM
noob help juanam0909 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-28-2013 01:17 PM
Im a noob at this... CSI:86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-30-2013 12:20 PM
Noob to this. Style Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 08:10 PM
Noob how often do you check you oil Fugazi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 07-06-2012 05:58 PM
