Drives: SWP BRZ 6 Speed Limited #888
Noob how often do you check you oil
I checked mine after 1k and. It looked like normal yellowish color to me.
I got nervous after reading the forums of a dealer not putting in transmission fluid. So do you check yours every week or do many miles? |
Drives: 2013 FR-S Hot Lava, 2007 Tundra
I check under my car more often than I check the dip stick. Looking at the oil itself can be helpful when I've blown a gasket, but I honestly don't expect that, so I only look at the dipstick when I change the oil to confirm I've added enough.
Senior Rocket Bunny
Drives: 1982 XX KE70
Whenever i want to perv on my motor... In my 6 Litre it was often.... Probably even more so when i attach a snail to the 86.. But as b.e stated above its always good to check under the car.... Obviously if there is any leaks thats where u will find it.... Also before and after ever track day.....
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
You should check your oil level at every fill-up. Monitoring your oil level can help you catch developing problems if you suddenly see higher consumption levels.
First 86
Drives: Scion FRS Argento Automatic
I check mine twice a week until about 5000 miles, then once per week.
Life is short...NO BORING CARS |
Drives: 2013 BRZ Premium 6MT
if its a a new unmodified car under warranty? prolly once a month
once engine/power mods are added i would check more often to make sure nothing is going wrong.
2013 Subaru BRZ Premium 6MT -STOCK!
Drives: 2009 370z 6MT
I don't check my oil very often to be honest. About once a month. If the car has been modified, I would definitely check it more due to the aftermarket parts potentially causing problems.
Drives: 2006 Evo IX SE
I check my oil every time I fill up at the gas station and also after every service.
Drives: 91 Corolla (dd) S14 (daily drifter)
Once a month when its cold.
#10 |
Drives: WRB BRZ Limited (AT)
Huh. Checked mine and there wasn't a drop of oil in there. Apparently they filled it with unicorn blood instead? Anyone else run into this? Seems to run fine, in any case.
#11 |
Drives: Strawberry Pie
Who got juked with no tranny fluid?
#12 |
Reverse Burnouts
Drives: 2013 Argento FRS
I check my oil when im filling up at the gas station
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
| Noob lowering question. | bazguitarman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-21-2012 03:53 PM |
| Noob question | fitcious | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-02-2012 11:18 PM |
| Noob to the forum! | Altezza_86 | Off-Topic Lounge [WARNING: NO POLITICS] | 14 | 12-19-2011 05:34 PM |
