Old 06-11-2014, 11:02 PM   #1
Venator
Venator's Avatar
Drives: Asphalt FR-S
Why is nobody making catted UEL headers except ft86speedfactory?
WHY!? Their lead time is ridiculous, and I get it. But why aren't there any others out there?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 06-11-2014, 11:46 PM   #2
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Just a guess, but probably because a catted UEL generates less power overall? Which probably means less interest from buyers. Plus I'd imagine most people with catted headers don't get a tune to preserve the warranty/emissions as much as possible. I went with a catless UEL and tune specifically because I wanted to make more use able power.
Sent from my XT1056 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 06-12-2014, 12:15 AM   #3
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
The high flow spun metallic cats are not very restrictive IMO. They will still make good numbers. I have a catted UEL here, has never been tested or posted about, weren't sure if we wanted to pursue them. The cat required for it is more expensive than the one used in the EL header, the runner layout is also quite a bit different than our non catted UEL. There's also no absolute guarantee that you won't eventually throw a CEL on stock tune nor pass emissions in places like California. Basically we weren't sure if the price increase could be justified with the only guarantee being maybe passing a visual inspection and reducing noise/rasp.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 06-12-2014, 12:32 AM   #4
jflogerzi
jflogerzi's Avatar
You would never pass smog in CA as replacing any cat with anything but OEM would cause you to fail.
Old 06-12-2014, 04:08 AM   #5
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
We need MORE (EL) catted options if anything.
Old 06-12-2014, 08:11 AM   #6
dabocx
dabocx's Avatar
Drives: Scion FRS
I don't too many people are worried about emissions and most would rather have one cat in the front pipe
dabocx is offline   Reply With Quote
Old 06-12-2014, 09:29 AM   #7
Venator
Venator's Avatar
Some places require the same amount of cats as factory, here they do a visual inspection to make sure you have whatever was put in place by the factory.
Old 06-12-2014, 09:39 AM   #8
Venator
Venator's Avatar
Sorry I guess I am just venting because I am getting a SC and tune in Aug and can't find a catted UEL before sept-oct if I order it today.. Lead times are excessive.
Old 06-12-2014, 09:49 AM   #9
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
My catted header sits on a shelf, cat is toast,literally it just a ball that will pass out thru the tail pipe one of these days
Avoid catted header.
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-12-2014, 09:49 AM   #10
husker741
I'll sell you mine for $3k.
husker741 is offline   Reply With Quote
Old 06-12-2014, 09:49 AM   #11
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
sounds like some people need to slip their emmisions guys a 50 or swap the stock header back on the car for testing... w00t for living in a becauseracecar state with no inspections lol
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-12-2014, 10:05 AM   #12
kiichiro
Bingo
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 06-12-2014, 10:48 AM   #13
stevesnj
stevesnj's Avatar
Fitting the OEM cat to this header would cost more but last for the lifetime of the vehicle and never throw a code. Expensive, yes. But if this will be a solution than it could be worth it in the long run.
If this could be made so the OEM cat could be welded on then I would go for it.
Old 06-12-2014, 01:08 PM   #14
wparsons
wparsons's Avatar
The OEM cat is a big restriction though, WAY worse than a good high flow cat.
flickr
FT86Speedfactory Catted UEL Header review! (Photos and Videos) fender9530 Engine, Exhaust, Transmission 72 06-20-2019 11:16 AM
Catted Headers EN2_Squirrel Engine, Exhaust, Transmission 53 12-16-2016 09:52 PM
Top Speed Pro-1 Catted UEL Headers. Hotlava86 Engine, Exhaust, Transmission 64 08-17-2015 02:44 PM
Decision making for headers Ravenft86 BRZ First-Gen (2012+) — General Topics 19 07-01-2013 12:50 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
