ST Coils, 1" Drop: 17x9 will +35 poke?
I think I'm finally coming into the home stretch as to what wheels I'm going to get. I recently got ST Coils and dropped my car 1" (would've gone more, but NJ potholes are NASTY).
Now I'm considering the RPF1 17x9 in +35 offset, this should sit pretty flush with my setup right? Or am I looking at some poke and need a bigger offset? I checked the tire/wheel calculator page and it -looks- like the +35 should be fine, but I was hoping for some confirmation. Thanks.
you should be fine as long as you dial in some negative camber.
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Ok, here comes the newb question...I only got the coils, no camber/caster plates or LCAs.
Am I able to adjust the camber without those items? Should I just go with a bigger offset? Sorry for my lack of knowledge, I'm still filling in gaps. Thanks.
#5 | |
Just drive it
Drives: 13' FR-S
I lowered my car 1 inch on springs and my rear cambers are 1.9. |
#6 | |
Time Traveller
The rears you cannot adjust, but after a 1" drop will get about -1 to -1.5 degrees of "natural" negative camber so they should tuck nicely. Use the calculator here to check. http://www.frsproject.com/tire_size.php |
#7 | |
Your rear should see between -1.8 to -2.1 degrees of camber with a 1 inch drop. Hope this helps. |
#8 | |
Thanks for the info folks.
So I wanted to check-in to make sure.
#9 | |
#10 |
Drives: FRS
i have 17x9 +38 with 245/40/17 tires. 1" drop with hotchkis springs.
rear camber (non-adjustable) came to -2.0 degrees. front camber with whiteline adjustable camber bolts maxed out at only -1.3 degrees. from the top view (looking down at the wheel from fender), my wheel is aaaaaalmost flush (pokes about 1mm). with a +35 wheel, you'll be poking just a tiny bit more unless you can get more camber dialed in.
#11 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I'm curious to learn from all that are running this setup as well since I want to run this exact configuration with either Volk TE37Vs, Weds TC105ns, or Enkei RPF1s. With "natural" camber maxed with the assistance of camber bolts, seems to be close to flush but curious if you rub if you hit a dip on the freeway (esp in front) seems like rolling of the fenders may be a good idea. To me 17x8.5 +35mm square may be the more perfect size (from a performance perspective) since you probably won't rub at all.
#12 |
Drives: FR-S Firestorm 6MT
I'm running 18x9 +35 and no issues at all. Overall tire diameter is the same, only difference is the tire is closer to the perch on the 17" setup whereas the 18" wheelrim is closer on mine.
My camber settings are -2.2 front and -2.0 rear with Eibach ProKits lowered by 1". No LCA's in the rear but crash bolts in the front (hole widened for a bit extra camber). To the OP, you won't rub at all. With the 1" drop, you'll gain enough camber to tuck those tires in. Great tire & wheel combo, will be my track setup shortly. |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 17x9.0 +38 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 10-31-2019 04:22 PM |
| * Axis OG SAN Wheel - 17x8", 17x9" - SALE * | GuerillaRacing | Wheels and Tires | 105 | 07-31-2014 06:01 PM |
| Poke's BRZ build | Pokeguyjai | Member's Car Journals | 5 | 03-15-2014 11:10 AM |
| Is there a 17x9 no poke option? | Amadeus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 07-04-2013 09:23 AM |
| What is the "best" drop in filter? | Osiris | Engine, Exhaust, Transmission | 10 | 04-04-2013 04:39 AM |
