Old 01-02-2013, 02:13 PM   #1
RavSpec
Drives: Rx7
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 17x9.0 +38
WORK Emotion Kiwami - 17x9.0 +38mm 5x100
Tires: 225/45 Blizzak
Camber: Negative 2.5 now, but will fit with stock cambers
Suspension: BC Coil Over, but will work without any spring or coil over upgrade
RavSpec is offline   Reply With Quote
The Following 7 Users Say Thank You to RavSpec For This Useful Post:
Astroboy (01-19-2014), GTHachiRoku (03-29-2014), JoeBoxer (01-02-2013), nix (01-10-2013), NWFRS (01-20-2015), Vic4uf (05-29-2017), Zaku (02-26-2013)
Old 01-02-2013, 03:12 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
It looked good on the floor of your shop, looks even better on your car!
Really digging the white on white.
Old 01-02-2013, 03:16 PM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
You would have Works for winter wheels!
JoeBoxer is offline   Reply With Quote
Old 01-02-2013, 03:31 PM   #4
RavSpec
Drives: Rx7
yeah, went with WORK For winter wheels and took off the TE37SL
Old 01-02-2013, 03:32 PM   #5
RavSpec
Drives: Rx7
Thanks Jim !!!
Waiting for your pictures and put on those special edition stickers too !
Old 01-03-2013, 12:51 AM   #6
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Weight? Also, any other colors?
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 01-03-2013, 12:57 AM   #7
RavSpec
Drives: Rx7
~ 21 lbs
And have bronze color
Sent from my iPad using Tapatalk HD
Old 01-03-2013, 02:58 PM   #8
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
What camber are you running?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-03-2013, 03:08 PM   #9
RavSpec
Drives: Rx7
~ negative 2 camber.
Old 01-08-2013, 02:55 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
This should be a perfect rear flush fitment!
The Following User Says Thank You to DarrenDriven For This Useful Post:
Hicklinc (03-23-2017)
Old 01-10-2013, 02:39 AM   #11
HATED1
HATED1's Avatar
Drives: 86
very nice
HATED1 is offline   Reply With Quote
Old 01-10-2013, 02:50 AM   #12
nix
nix's Avatar
Drives: AVO BRZ
Nice!
nix is offline   Reply With Quote
Old 01-10-2013, 04:40 PM   #13
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
where do you work and how do i apply?
garf is offline   Reply With Quote
Old 01-14-2013, 03:26 PM   #14
FRZ
FRZ's Avatar
Drives: Subaru BRZ
Love it!
What is largest tire you can run on those without rubbing and zero camber? Would 245/40 fit?
The kiwami's are suprisingly concave for a +38 offset!
FRZ is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 04:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x7.5 +47 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-31-2012 04:17 PM
