Old 06-10-2014, 10:52 AM   #1
beforprez
beforprez's Avatar
Drives: 2013 Auto FR-S
Greddy kit dyno sheet
Here are my new #'s after having some new stuff put on and tuned.
Sent from my HTC6435LVW using Tapatalk
beforprez is offline   Reply With Quote
Old 06-10-2014, 10:53 AM   #2
beforprez
beforprez's Avatar
My bad dyno sheet pic turned out bad will try another later that is actually legible
Old 06-10-2014, 10:56 AM   #3
beforprez
beforprez's Avatar
Tried lightening it up a bit
Old 06-10-2014, 11:12 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Looks the same to me. Not bad numbers on 93 octane. Dat torque curve. It looks like you made 281 hp and 243 ft-lbs. My guess is that you are dropping a couple PSI past 6300 RPM which is when the torque starts dropping and why you didn't end up making a larger horsepower number.
Old 06-10-2014, 11:12 AM   #5
beforprez
beforprez's Avatar
The 281 is on e85
Old 06-10-2014, 11:13 AM   #6
beforprez
beforprez's Avatar
250 on 93
Old 06-10-2014, 11:14 AM   #7
beforprez
beforprez's Avatar
93 it's 7-8lbs of boost and on e85 it's 11-12
Old 06-10-2014, 11:17 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You can definitely run more boost than that on 93 octane and on E85 before that turbo will run out of steam.
Old 06-10-2014, 11:57 AM   #9
beforprez
beforprez's Avatar
So how I crank that up haha
Old 06-10-2014, 11:57 AM   #10
beforprez
beforprez's Avatar
It seemed low coming outta there, it was a mustang dyno for what it's worth
Old 06-10-2014, 12:02 PM   #11
Fear
Drives: Ft86
i wouldn't worry about the dyno, you should have been in the 10psi range on the 93 and the 15-20psi range for the e85... roughly.
At least this is what i've found in my research.
Fear is offline   Reply With Quote
Old 06-10-2014, 12:11 PM   #12
beforprez
beforprez's Avatar
I've heard 14psi is pretty much the end for greddy's kit
Old 06-10-2014, 12:18 PM   #13
Fear
Drives: Ft86
eww.. well, guess that's another reason I'm glad i didn't go with them.
guess you could upgrade the turbo later
Old 06-10-2014, 12:19 PM   #14
beforprez
beforprez's Avatar
Ya I acquired this one I didn't buy this kit. I'm prob gonna take it off and sell it and buy a different one this winter maybe
Stock Dyno vs GReddy Intake Dyno JTOFJPN Engine, Exhaust, Transmission 0 06-01-2014 03:56 AM
Dyno results from R/T Tuning Greddy turbo FRS R/T Tuning NY / NJ / CT / PA 1 10-12-2013 07:38 PM
GReddy Tuner T518Z Turbo Kit Fitted / Photos/ DYNO/ Video ! NOTORIOUS.BRZ Forced Induction 17 07-29-2013 04:42 PM
Dyno on the Greddy SP ? rikdrt1 Engine, Exhaust, Transmission 7 09-13-2012 09:46 PM
The Subieyota Is Under This Sheet ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 42 11-23-2010 08:42 PM
