Old 12-18-2013, 03:03 PM   #1
Hakuzen
Drives: 2014 Scion FR-S
Should I let Toyota replace my fuel pump?
Hello,
During maintenance the service tech noticed there was a new fuel pump available for my car and ordered it.
The fuel pump arrived and they want me to bring my car in, but the thing is.. It's the SU003-05176 pump, which has already been confirmed to NOT FIX the crickets.
I told him that, but he still wanted me to bring the car in anyway. He is dead set on installing it.
Should I do it? Will I be punished for refusing to let them put the pump in?
I just don't see the point if the pump doesn't fix the issue, but these guys are really insisting on it.
Thanks!
Hakuzen is offline   Reply With Quote
Old 12-18-2013, 03:48 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You wont be refused, but I guess they could deny you further fixes to fuel related issues somehow? Also the crickets are not caused by fuel pumps at all...so yep. not going to fix your crickets
Old 12-18-2013, 04:41 PM   #3
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
What are you talking about? The High Pressure Fuel Pump is the most common cause of the cricket noise...I know, I just had mine replaced with the NEW revised pump...and guess what, no more crickets. Get your fact straight.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 12-18-2013, 04:43 PM   #4
Hakuzen
Was this part SU003-05176? Or is there an even newer one out?
Old 12-18-2013, 05:20 PM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
not everyone has permanent fix.
some people had success but came back later.
some people had same problem like old pump.
how many mileage and period time since you replaced pump?
this will help other people.
I didn't bother take it to the dealer to fix it
1. I see they don't have permanent solution yet.
2. I don't want to waste my time
Until there is permanent fix, i won't go in and replace pump every time they get new one.
Old 12-18-2013, 05:30 PM   #6
Mr.EvoMR
Mr.EvoMR's Avatar
Drives: 2013 Scion Fr-s
I would not have them replace it. Like you are saying, they do not have a fix, so why keep swapping it out with nothing changing, it's a waste of time, unless it's a fix. But if they do refuse to help you with it later because you chose not swap it out now(which i think they won't do) i would just do it. Good luck!
Mr.EvoMR is offline   Reply With Quote
Old 12-18-2013, 05:36 PM   #7
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
I would hold off on it. The way I see it is that everytime your car is under repair is another chance for 'complications'.
It's like needless surgery if it doesn't fix anything.
"I can't cure your cancer but I can give you a lung transplant for free!".
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 12-18-2013, 05:48 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
You have a 2014 FRS.... you never confirmed if you have crickets though....
Also, if you do have crickets, what is your build date?
Old 12-18-2013, 06:12 PM   #9
Boxer486
Drives: small
If you don't have crickets, leave well enough alone. Always refuse anyone wanting to touch your car that doesn't have to. Would have thought the 2014 would have already had the latest pump in it anyway...
Boxer486 is offline   Reply With Quote
Old 12-18-2013, 06:26 PM   #10
Hakuzen
I do get crickets, but only when it is warm out and the engine has been running for awhile. They come and go.
The latest pump seems to have been released back in mid-october, which is a few weeks after I purchased the car.
At this point i'm very hesitant, as I just don't see a point if the pump is confirmed to have not fixed the issue for most if not all people.
Old 12-18-2013, 09:22 PM   #11
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
For your reference: http://tbertran-misc.s3.amazonaws.co...uelpumpTSB.pdf
I've had that issue since I got the car 16 months ago but, like you, every time it happens it's when the car is well warmed up (usually not close to dealership or when they're closed).
They've always insisted that they wanted to see the problem in action before doing any replacement so there's something good about having a proactive service tech...
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 12-18-2013, 11:49 PM   #12
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Love your circumstantial evidence
Old 12-19-2013, 12:51 AM   #13
Mo707
Mo707's Avatar
The original part number superseded to another one. They no longer make the old one. SU003-05176 is the new number
Mo707 is offline   Reply With Quote
Old 12-19-2013, 12:52 AM   #14
N1rve
N1rve's Avatar
What is your FRS' build date?
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
High Pressure Fuel Pump Difference? Toyota vs. Subaru 86_ZN6 Engine, Exhaust, Transmission 18 06-03-2013 06:48 AM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
