Old 06-09-2014, 12:15 AM   #1
1BadFA20
Drives: '92 GS-R, '02 RSX-S, '14 BRZ
Electronic Boost Controller Issues
So this is my situation. I have been running a 4 port Mac solenoid ebc plug and play since day one I was boosted. Running 3 maps. 7psi, 11psi and 15psi. Map one holds steady and true. Map two tops at 13psi. Map three I haven't ran as my clutch was slipping on map two so I don't know where it hits. I ran the 4 port as follows:
IN port - To compressor
EX port - Vented
A port - Top of wastegate
B port - Bottom of wastegate
I was instructed to use a 3 port ebc vs. the 4 port I have been using. Mind you the 4 port is fine and has no issues aside from 2psi over on map two and known overage on map three. I purchased a Dynosty ebc. It's a Mac solenoid plug and play. Here is my results:
1st hookup
Port 1 - To compressor housing w/tee to wastegate bottom port
Port 2 - Top port on wastegate
Port 3 - Vented
Result - 7psi on every map
2nd hookup
Port 2 - Bottom of wastegate
Port 3 - Vented
3rd hookup
Port 1 - To bottom of wastegate
Port 2 - To compressor housing
Port 3 - Vented
Result - I hit 15 psi+ keeps climbing so I let off every map
4th hookup
Port 1 - Vented
Port 2 - To bottom of wastegate
Port 3 - to compressor housing
So I am at a loss on how to run the lines. Can anyone shed some light??? Makes me want to install the 4 port and live with the 2psi over........
PTE 5758, Turbosmart, JDL, Perrin, Tein, Rays Gramlights, Sumitomo, Raceseng, Beatrush, Buddy Club, Valenti, DSS, Act, Cartboy, Mtec, APR, Beatsonic, FA20CLUB, Radium, JPM Coachworks, VIS, Recaro, IAG, Cleib, Nameless, Zele
Coming soon: Garage Vary, Cleib, Cravenspeed, VEI
1BadFA20 is offline   Reply With Quote
Old 06-09-2014, 01:21 AM   #2
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I suggest you read this blog, every page. Each boost solenoid will have a diagram of how to connect it. There are two ways to properly connect a 3 port with an external wastegate.
http://blog.perrinperformance.com/bo...ems-explained/
rb6freak is offline   Reply With Quote
AVO DBW electronic throttle controller Setup AVOturboworld DIY (Do-It-Yourself) Guides 22 03-31-2016 06:11 PM
Prodrive Boost Controller Installation pixel67 Forced Induction 12 05-02-2014 02:32 AM
FS Hallman Pro RX Manual Boost Controller Sportsguy83 Engine, Exhaust, Bolt-Ons 2 02-28-2014 11:15 AM
Fuel economy and electronic toy-86-throttle-controller what do you think? dssence Scion FR-S / Toyota 86 GT86 General Forum 44 02-27-2014 06:40 AM
Turbosmart E-boost controller Fl4t fun Engine, Exhaust, Bolt-Ons 0 01-29-2014 11:29 PM
