Drives: 13 Asphalt FRS AT
Prodrive Boost Controller Installation
Guys, I am in search of some guidance on this. You would think something with only 3 connections would be easy to figure out and well documented somewhere but that doesn't seem to be the case. I had this installed by another shop and ran into an issue where even though the tune has 4 switchable maps with different boost settings, I am only seeing wastegate pressures regardless of map selection. I have verified through ecutek logs that it is indeed loading the map selection and have verified the harness connectivity. This is the only illustration i could find on installation and it isn't specific to this vehicle:
![]() ![]() Mine is not set up this way at all. They mounted it up front and the harness is facing forward. Port 3 is connected to the turbo inlet, Port 2 is connected to the base of the wastegate (all other holes are plugged), and Port 1 is actually connected back to the vacuum block with a T connector that is shared with AEM Failsafe. Here is a video showing the above connections. [ame="http://www.youtube.com/watch?v=AOrQlo1pZ5o"]Turbo frs boost controller - YouTube[/ame] Any and all feedback is welcome.
Drives: 23 BRZ
Have you checked the two wire cable to make sure the connection is functional? Chances are that the wiring was extended.
Port 1 can be left to vent to atmosphere, just point it down so no fluid gets trapped. |
At one time the harness was a problem and it threw CEL. Fixed the harness and current is passing through it now. I am more concerned about port connections. Port 1 is currently running back to the vacuum block. Port 3 is currently connected to turbo inlet.
#4 | |
Drives: 23 BRZ
![]() I.e. the left nipple on this WG. |
#5 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Sadly, I believe it is a turbo owner education issue (big surprise, right?). Port 3 is connected to the turbo, port 2 is connected to the wastegate, however port 1 is plumbed back to the vacuum block. The Vacuum block connection threw me off as well as the mix of terminology (turbo inlet, compressor housing).
#7 | |
I Love custom Turbo kits
Drives: Limited BRZ
It would seem a custom map issue? are the custom maps enabled? If its a locked tune, only your tuner can verify all custom maps are active in maps 1,2,3,4 and not only in debug mode, logabble but not active.
#8 | |
Drives: 23 BRZ
Its either the tune or a bad cable / connector. When you had the CEL initially it was most likely because you unplugged the factory connector and the tune didn't compensate for that. Do your part and triple check that cable to make sure you have a signal on both lines. If you do, you're good to go at pointing the finger at the tuner (assuming your pro-drive is working). |
#9 | |
1. I am a dumbass and should have done more homework on boost control fundamentals before messing with it on my car. 2. When i fixed the harness connection, I also replaced the vent on top of the wastegate with a plug so it is sealed. So even though i fixed it in #1, I broke it again in #2. Leave it to me to learn everything the hard way...
#10 | |
Drives: Limited BRZ
![]() #2 definitely, VTA.
#11 |
Drives: 23 BRZ
One more thing. Slip that WG hose in thermal sleeve. With the amount of exhaust heat near that hose it will eventually crack. Fire sleeve, thermal wrap, whatever its called. Just buy a few feet of 1/2 or 5/8 ID hose and cut to length, slip over hose.
#12 |
Thought you guys might be interested in the result. This time i was going to make changes one at a time so I can see the effect. I reinstalled the vent on the wastegate and took it out for a short spin but that didn't seem to help drivability at all. It was still running rough as hell so I removed the connection between port 1 and the vacuum block, put an elbow on the solenoid connection and capped off the T connection, and bam! Back to running as smooth as it was before. We still have some work to do on injector scaling so there is some low end bog as it runs quite rich. But at least it doesn't feel like it is going to cut out. Took it out for a quick spin and boost control appears to be functional but it only raising it to 8psi so far on map 4. We may have to make some compensations for backpressure as my wastegate is now recirculated and two high flow cats are in place.
So, any ideas why plumbing port 1 back into the vacuum block would cause such erratic behavior?
#13 |
Drives: Pegasus GTS86
The only reason I can think of it being a problem could be that the air coming from Port 1 is being fed into the engine after the throttle body. I've usually seen it described as being plumbed back into the inlet after the maf but before the throttle body. I'm no expert though. Just trying to understand it myself.
Sent from my GT-I9505 using Tapatalk |
| FS Perrin Manual Boost Controller (MBC) | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 5 | 04-29-2014 03:04 PM |
| FS: Full Blown Manual Boost Controller | woode | Engine, Exhaust, Bolt-Ons | 0 | 02-28-2014 11:36 AM |
| FS Hallman Pro RX Manual Boost Controller | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 2 | 02-28-2014 11:15 AM |
| Turbosmart E-boost controller | Fl4t fun | Engine, Exhaust, Bolt-Ons | 0 | 01-29-2014 11:29 PM |
| Greddy New Profec Boost Controller | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 4 | 01-16-2013 06:12 PM |
