Old 08-31-2012, 07:34 PM   #1
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
AVO DBW electronic throttle controller Setup
I just made a quick video of setting up the DBW controller, as that's the most common question I get.
[ame="http://www.youtube.com/watch?v=xYijoYmeZXU&feature=player_embedded"]AVO DBW Controller Setup[/ame]
Actually installing the unit is quite easy, other than the fact you have to lie upside down underneath your dash in a fairly tiny space.
1. Locate the wiring harness at the top of the Throttle Pedal Box, connected to, of course, your throttle pedal. Unclip that harness, and clip the supplied male portion of the T harness into the OEM harness, and the female portion of the T harness into the pedal box assembly.
2. Attach the supplied OBD-II port adapter to the OBD-II port. That supplies power to the main unit.
3. Place the controller itself whereever you prefer on your dash, hook it up to the main unit, and get ready to set it up!
AVOturboworld is offline   Reply With Quote
Old 09-01-2012, 03:10 PM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 09-09-2012, 11:37 PM   #3
gmookher
what does it do?
how does it work?
anyone tried this?
gmookher is offline   Reply With Quote
Old 09-09-2012, 11:51 PM   #4
AVOturboworld
Well, the one thing it doesn't do is add power, though it may give the feeling of more power. Drive By Wire electronic controllers do just that, adjust the dbw throttle response to pedal input.
It works via install of a t-harness that plugs inbetween the oem harness and pedal box, which allows the dbw controller to modulate the voltage output. It's similar to the SI-drive on Subaru Legacies, except there is a bit more adjustability.
I don't know if anybody here has tried it, though there is a few fr-s/brz owners that I've sold to already. Sold many of them to Subaru owners over the past year+ though, you can probably find more feedback on the Subaru forums.
Old 09-10-2012, 03:31 PM   #5
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Would this help dial in the lower pedal voltages to be a little more peppy and not quite as "jumpy" at low speeds?
Norkoastal is offline   Reply With Quote
Old 09-10-2012, 03:44 PM   #6
AVOturboworld
From personal experience, yes. I'm finding it easier to rev-match now thanks to that.
Old 09-10-2012, 06:11 PM   #7
gmookher
I could see this being of value when I do a FI solution
Old 09-11-2012, 05:41 PM   #8
Norkoastal
Norkoastal's Avatar
Very interested in this product.. Can you tell me what happens if the unit shorts/malfunctions while driving? Is all power lost or does the unit revert back to stock settings? Knowing this thing will cycle every day once plugged in, I may be a bit leery if there is a short or another anomoly that renders my throttle to mush.
Old 09-11-2012, 09:00 PM   #9
xcelir8brz
Drives: 2013 BRZ Limited
I had something like this on my 2011 Fit. It doesn't add power, per se, however, it allows you to zero in on when you want the throttle plate open during certain driving conditions (i.e. passing someone), etc.
Paul - where did you get it and how much? I like this unit better than the one I had on my Fit. I'd be interested in getting one.
xcelir8brz is offline   Reply With Quote
Old 09-12-2012, 12:24 PM   #10
AVOturboworld
It just reverts to stock settings, though I've honestly never heard of a unit shorting out. Even if the main unit was fully disconnected, the throttle/pedal would be at OEM response.
Old 09-12-2012, 12:25 PM   #11
AVOturboworld
It's our AVO branded unit, with a bit of tweaking for Subaru's setup. I've been selling them for over a year on other Subaru models. They are $199.00 through our online shop.
Old 09-13-2012, 03:18 AM   #12
spomi
spomi's Avatar
Drives: 2009 Impreza
May be it is a stupid question. If I buy one now and put that in my impreza. Can I yank it out later and reprogram it to a brz when I get one?
spomi is offline   Reply With Quote
Old 09-13-2012, 12:08 PM   #13
AVOturboworld
Yes, actually, you can. The Subaru BRZ/FR-S is using the same setup as the 2008+ Impreza/STI models.
Old 09-15-2012, 10:16 PM   #14
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
wow awesome! its like an electric "throttle cable" adjuster, unlike the old days where we all had to adjust the old school throttle cables with adjusting the nuts lol.
driftartist is offline   Reply With Quote
APEX-i SMART Throttle Controller - preliminary test. Moto-P Engine, Exhaust, Transmission 33 05-24-2015 07:01 PM
Scosche touchscreen A/C controller DIREWOLF Electronics | Audio | NAV | Infotainment 46 03-30-2013 07:42 PM
Electronic Driving Aids trackmagic Scion FR-S / Toyota 86 GT86 General Forum 20 03-07-2013 07:45 PM
Control Your Thorttle Output with the Weapon R I-Throttle Controller !! PRO Import Tuners Engine, Exhaust, Bolt-Ons 16 08-14-2012 07:10 PM
