| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Toyota 86
DIY: FR-S and GT86 Amber cluster backlight (no soldering)
Hey guys just want to share what I did today. I used some translucent amber sheets to change the color of the gauges from white to amber. Here are the pros and cons of this mod before you decide to try it out for yourself..
Pros: -100% reversible -no need to remove the needles and risk messing up the needle motors -dirt cheap -relatively easy to do Cons: -backlight is a little dimmer compared to stock, but not by much. This can be a pro because since the backlight is a little dimmer, the Shift light is now more noticeable. DISCLAIMER: I am not responsible if you f*ck something up. Do this mod at your own risk. It should be really easy if you're handy with a pair of scissors ![]() Follow the DIY on removing the cluster hood here: [ame="https://www.youtube.com/watch?v=3NU5ba3ChgM"]Remove the Gauge Cluster of FR-S, BRZ - YouTube[/ame] And how to disassemble the cluster itself: http://www.ft86club.com/forums/showthread.php?t=58207 Once the cluster is disassembled, you will have something like this ![]() Now you need to find something that will change the light from white to amber. I used a "clear book" folder I bought from an office supplies store. It's a folder with a translucent cover and clear plastic sheets inside that you can stuff documents into. Cost me 45 pesos or 1 US Dollar ![]() ![]() As you can see, it changes white light to amber ![]() Begin by cutting a pattern similar to the one in the photo. Use a sharpie to mark where you need to cut. ![]() You will end up with something like this ![]() Now repeat the same thing for the tach. Make sure you don't cover any of the warning lights ![]() ![]() And finally the fuel and temperature gauges ![]() Slide the amber "diffusers" underneath and use some tape to secure them ![]() Reassemble everything and enjoy the fruits of your labor ![]() Matches my Defi Advance CR gauges really well ![]() ![]() Comparison of the stock tach and modded speedometer ![]()
Drives: 2014 BRZ - 2004 GLI
Nice simple diy!
Yup.
Drives: MT Subaru BRZ '13
Didn't know what to expect but I like it a lot! Nicely done.
Drives: TRD Ultramarine '13
If I ever do this, I'll do blue!
Drives: Toyota 86
^ I'm curious as to what it will look like with blue. I used the same method to change the backlight of the Defi boost gauge in my 90s Land Cruiser from white to green. Turned out great too!
siiiiiiiiiiiiiiiiiiick!!! Nicely done!
Drives: '13 FR-S
That's pretty nice, though it reminds me of 90's pontiacs with all that orange, lol. Great idea on using the folder.
Drives: Only ridiculous cars
Drives: DGM BRZ 6MT
Wow, very creative!
#10 |
Drives: SWP BRZ
That folder cover looks a bit thick. Try some lighting gels from Rosco or Lee, usually available from your local camera store.
http://www.adorama.com/catalog.tpl?o...Feature1=Rosco |
#11 | |
#12 |
The Mechanic
Drives: Civic Turbo,FR-S
thats a great idea. the lights are too bright on the dash anyway lol i cant stand the 8 different colors they use
#13 |
/dev/null
Drives: Uphill
That looks awesome!
Thanks for sharing :-) |
#14 |
Drives: '14 Subaru BRZ
| led cluster help | Grip Ronin | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-14-2014 12:29 PM |
| Daytime dash backlight | k0tkmnd | Electronics | Audio | NAV | Infotainment | 1 | 10-18-2013 07:01 PM |
| Soldering questions | Xdragonxb0i | Electronics | Audio | NAV | Infotainment | 12 | 01-21-2013 01:22 AM |
