Northwest AK, ID, OR, WA
Old 06-07-2014, 10:05 AM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
thought I heard rod knock this morning..
Det, Ping, Knock, Rod Knock, etc.
I had to take my girl to work this morning, and when I was sitting at idle, I thought I heard some faint "pinging" noise. No unusual characteristics while driving, and can't hear the knock noise while cruising. Only at idle, I think I hear something.
When I drove back home, the sound was gone. Tried to see if something was just rattling in the engine bay or not.
Fuck, already for a engine rebuild time!?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following User Says Thank You to BRZPDX For This Useful Post:
evan (06-07-2014)
Old 06-07-2014, 11:28 AM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
That might be a bit extreme, these engines are noisy little critters and make all kinds of very very sick engine sounds right from the showroom floor.
That being said, the occasional knocking (as in predet, not rod knocking) is not going to hurt an engine in low load situations.
Decay107 is offline   Reply With Quote
Old 06-07-2014, 11:57 AM   #3
ramiram1984
Drives: 2016 STi DGM
Hmmm risky business
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 06-07-2014, 04:17 PM   #4
evan
Drives: fr-s
I too thought I had the same thing. It's not. You're probably fine. These motors snap, crackle & pop. You'll put a happy 100k miles on your motor is my prediction.
I realize you're automatic, but you should hear it with an upgraded clutch and new throwout bearing. It's a tad noisy.
evan is offline   Reply With Quote
Old 06-07-2014, 05:16 PM   #5
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Probably needs more boost.
Chen is offline   Reply With Quote
The Following 4 Users Say Thank You to Chen For This Useful Post:
Astroboy (10-30-2014), DarrenDriven (06-08-2014), Mongo (06-25-2014), PoWn3d_0704 (06-08-2014)
Old 06-08-2014, 12:19 AM   #6
BRZPDX
Boosted Member
BRZPDX's Avatar
now I have a voice in my head saying something might be wrong. Need to take it to PRE to have it diagnosed, and also to clamp the vacuum hoses under the manifold. @evan have you done those yet? Anything over 10psi, they recommend clamping all the vacuum lines that the factory did not (no boost, no positive vacuum?).
temps, AFR, boost looks good so far..
Old 06-08-2014, 01:42 AM   #7
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Well, I wouldnt worry too much about it, not if AFRs and everytrhing looks good. If you do hear something though, make sure to let us all know.
Will keep my wallet fuller.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 06-08-2014, 03:32 AM   #8
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Do the vacuum hoses Kohei. I need to do it too. I met up with another KW kit guy in Seattle and his hose under the intake manifold had just popped off after a track day.
digital_assassin is offline   Reply With Quote
Old 06-08-2014, 11:07 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If the vacuum hoses under manifold came loose, the car would not idle, so rule that one out.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
evan (06-08-2014)
Old 06-08-2014, 09:22 PM   #10
evan
Drives: fr-s
I haven't done them yet. I don't have the stock manifold anymore, obviously, but I do need to check on my setup. I need to take care of melting fittings from the header and supercharger this week.
Old 10-28-2014, 11:35 PM   #11
Astroboy
Astroboy's Avatar
Drives: None
Did you ever figure out the issue?
Astroboy is offline   Reply With Quote
Old 10-30-2014, 01:18 PM   #12
BRZPDX
Boosted Member
BRZPDX's Avatar
no, but its something hitting something under the engine, when its warmed up and only at idle. Its like a weird noise like a cat scraping the door but not rhythmically. Shit is such a tight fit, my car makes all sorts of funky noises..
Everything looks good so far, in 2 months I will reach my 1 year FI daily/track/auto-X. I will report it when the time comes.
I think the drivability is most affected by ride height with lip kits, not being FI..
Old 10-30-2014, 01:25 PM   #13
Astroboy
Astroboy's Avatar
Drives: None
Cool! Good to hear. Congrats
Old 11-05-2014, 04:30 AM   #14
Mr122
Drives: FRS
Even stock the gears chatter when it's cold.
Mr122 is offline   Reply With Quote
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
earthquake this morning! FRSGIRL❤ CANADA 9 05-19-2013 12:25 PM
So I heard you like FRS's Bach415 Scion FR-S / Toyota 86 GT86 General Forum 8 04-11-2013 08:36 PM
morning drive monkeedoo Northern California 3 04-03-2013 04:21 PM
