Long Distance Driver
Amsoil 0W-30 analysis, 10k on E85, 33K on motor
Decided since I barely see any oil analysis from other people running E85 I'd figure I could chime in,
Oil: Amsoil Signature Series 0W-30 Miles on interval: 4k Miles on Motor:33k Running E85 since 20K miles on OFT E85 tune other mods: TRD USA intake, Nameless EL Headers(ceramic coated), Motiv overpipe (ceramic coated), Motiv Catted Front pipe, Stock Midpipe, TRD Japan Quad axleback. This oil sample came with nothing but abuse, 1 very hot track day, around 5+ Autocross's, highly spirited drives, and highway driving. oil has seen temps well above 240 at times. After being on E85 since 20k and using this oil ever since the first oil change, I feel pretty comfy now and relaxed that the motor is looking healthy! most oil changes were done at 3-5k intervals
| The Following 11 Users Say Thank You to Sargy For This Useful Post: |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I don't run e85 so I have not done a ton of research, but do you need to change the oil more often when running it? Just curios if running Amsoil on 91 could go longer to say 10K miles.
#3 | |
![]() In regards to 91 in my opinion, it just depends how you drive. I cant comment on that. I have seen amsoil intervals much higher than 10k though.
#4 | |
| The Following User Says Thank You to finch1750 For This Useful Post: | Sargy (06-07-2014) |
#5 | |
Taking it out to 6k miles would probably drop the viscosity down to a 20 grade oil, but that's probably fine for your application. The 10W-30 would probably be more stable and I'd recommend that any day over a 0W-30 in an 86 that sees track time (especially if you have more than 1 track day vs. mainly auto-x). I know an Amsoil dealer that runs the SS 10W-30 in an Audi TT with great uoa's and the oil isn't even recommended for Audi's.
I'm surprised at the high universal averages for silicon. This is probably due to so many low mileage 86's doing uoa's or a lot of you guys running aftermarket intakes. A paper panel filter or an Amsoil Ea filter would probably drop silicon (dirt) down into the single digits. -Dennis Last edited by bluesubie; 06-19-2014 at 09:32 AM. |
Drives: small
Anyone have any thoughts on Amsoil versus Eneos Sustina? Have been pretty satisified by Amsoil in the past, was wondering if Sustina is worth the change performance wise. Particularly for hard use.
#8 | |
Drives: 2013 FRS / 2013 427 Vert
Realizing that it is just your opinion with no liability implied, do you recommend a specific vicosity and brand for a street driven car that sees 6-8 track weekends in the southeast? (driven hard on R-Comps but using an oil cooler) Thanks for all the input you have shared on this topic by the way
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#9 | |
![]() It's a tough call whether or not you need a dedicated race oil. Amsoil Dominator 5W-20 (to be somewhat on topic), Motul 300 0W-20, or Red Line 5W-20. The Motul and Red Line have more detergents, but even the Amsoil would be fine for a short interval of 3-4k-ish (or possibly longer based on uoa). Actually, Amsoil Signature Series 5W-20 might be a good fit. In general, I'd go with a 5W-20 over a 0W-20 (unless the 0W-20 is a race oil). 5W-20's are much more stable than most 0W-20's or 5W-30's. Compare the lower NOACK volatility among the Amsoil oils. -Dennis |
#10 | |
Drives: small
#11 | |
I thought I replied to this, but don't know what happened. It's probably fine if you use the 5W-30. Or mix and fine tune to the oil pressure needed for your conditions (if you have a gauge). IMO, for track conditions I would be looking for higher HTHS and lower NOACK, not an oil that is light at start-up. -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | Boxer486 (06-28-2014) |
#12 | |
Drives: Currently 2018 Taco
Detergents compete with anti wear components of the additive package. I see no particular evidence that 5w20 oils are generally more shear stable than 0W20 oils. However counterintuitive it may seem, higher quality base stocks are necessarily called for to create a 0W20 vs creation of a 5W20. Dennis, I am sure you are familiar with Doug Hillary on bitog. He states, in his expert opinion, that there is not any significant difference, in terms of wear, between a 5PPM and 75PPM number for Fe in a UOA. Doug Hillary has spent a lifetime studying service fleets in Australia and nurburgring race cars in Germany for the major oil companies. Now I have an off topic, off the wall question for y'all. I was browsing at Pep Boys today. On the shelf was Valvoline Nextgen Synthetic 5W20, at the opposite end of the Noack volatility index, from Amsoil. The price was $1.80/qt-no limit. How many quarts would you like to buy? (Insert Mr. Greenteeth.) Last edited by viscositosis.rex; 06-29-2014 at 09:38 AM. |
| Oil Analysis - 1st oil change | R L Newb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 375 | 11-19-2021 09:24 AM |
| CFD analysis of BRZ/FRS rear diffuser | Wonderbar | Cosmetic Modification (Interior/Exterior/Lighting) | 78 | 12-15-2014 05:53 PM |
| Question for oil junkies regarding Amsoil OE vs Amsoil Signature | Simon99 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 04-25-2014 10:48 AM |
| Used Oil Analysis Results | Captain Snooze | Engine, Exhaust, Transmission | 2 | 11-21-2013 12:59 PM |
