Old 11-20-2013, 10:50 PM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Used Oil Analysis Results
My car had done 15,565 kilometers when this uoa was done. It has had 4 oil and filter changes. The air filter was replaced at approx 12,000 kms and looked quite ok. The oil being analyzed had done 3921 kms. The results show raised aluminium and silicon levels; "Aluminium and silicon are often from dirt/dust ingress." but I don't know how this would occur. This is my first test so I have no idea of what to expect.
Would some one like to comment on the results?
Ta.
Old 11-21-2013, 04:23 AM   #2
Captain Snooze
Drives: Red Herring
Originally Posted by Monogram View Post
and are you running stock or oiled filter?
I am using stock air filter.
Old 11-21-2013, 12:59 PM   #3
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
You might want to check out this thread in the oil change forum. Lots of good info on UOA on the BRZ and FRS.
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
Captain Snooze (11-21-2013)
Oil Analysis - 1st oil change R L Newb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 375 11-19-2021 09:24 AM
CFD analysis of BRZ/FRS rear diffuser Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 78 12-15-2014 05:53 PM
ECUTek DTC/Readyness Analysis.... 2forme Software Tuning 41 10-08-2013 06:49 PM
Used Oil Analysis - Factory break-in oil CSG Mike Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-10-2012 01:06 AM
