Old 06-04-2014, 10:39 PM   #1
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Tarmac 2 recommended damper setup
Hey guys. I wanted to know what damper settings you guys were running in regard to the tarmac 2 coilovers.
Rocket.BRZ is offline   Reply With Quote
Old 06-04-2014, 10:50 PM   #2
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Please share track-only settings.
I know the RCE T2 manual has some settings for mix-use (both DD/Track) ...but pure-track settings would be nice. SoCal tracks too.
fooddude is offline   Reply With Quote
Old 06-05-2014, 04:48 PM   #3
Rocket.BRZ
@Racecomp Engineering
Old 06-06-2014, 10:08 AM   #4
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
http://racecompengineering.com/instr...ingsbrzfrs.pdf
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Draco-REX (06-06-2014), Racecomp Engineering (06-06-2014)
Old 06-06-2014, 01:22 PM   #5
Rocket.BRZ
Originally Posted by ATL BRZ View Post
Hoe about for pure track use?
Old 06-06-2014, 01:23 PM   #6
Rocket.BRZ
Do you offer external adjustment so I don't have to go underneath the car to adjust the dampers?
Old 06-06-2014, 01:42 PM   #7
The knobs are on top and bottom. The bottom can be reached with the wheel turned but it's tough to see unless you're laying down.
Those settings are good for the track.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
fooddude (06-06-2014)
Old 06-06-2014, 02:12 PM   #8
Rocket.BRZ
- Andy
which knob is for compression and which is for rebound?
Old 06-06-2014, 02:19 PM   #9
top and bottom? you can't adjust them from the camber plate?
RCE T2s are two way adjustable...separate knobs for compression and rebound. Gives you lots of control.
Rebound is easily reached on top at the camber plate.
Compression is on the bottom of the strut/shock.
- Andy
Old 06-20-2016, 11:17 AM   #10
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
- Andy
What's up guys at racecomp engineering
I noticed every time I get a stickier tire the car tends to roll once I start taking corners I've set up the dampers to where they felt great on federal rsr but I recently upgraded the tires to a more sticky tire the federal rsr rr and I have roll once again just want to get some input is it time to upgrade the springs or get sway bars runing negative-3 front camber and -2.5 rear lowered 1 inch all corners
el-92 is offline   Reply With Quote
Old 06-20-2016, 12:17 PM   #11
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
@Racecomp Engineering What do you guys consider to be the optimal right height on the T2's when not using bump steer correction kit? I run in STX class, so I have to leave those parts stock. Right now I'm dropped 30mm from stock, but wonder if I should raise it back up a bit?
smg1138 is offline   Reply With Quote
Old 06-20-2016, 02:52 PM   #12
Yes sir, more grip means more roll. Swaybars are an easy way to go and an adjustable set gives you some tuning options. Stiffer springs work too.
Remember a little roll is OKAY...but if you're rolling excessively and uncomfortable with the car's handling then yes some swaybars are a good next step.
- Andrew
Old 06-20-2016, 02:56 PM   #13
30mm is fine...I generally recommend 25mm for the 400/400 rates, sometimes with a very slight rake forward. 5mm ain't much difference.
You can go a little lower with firmer rates and/or more camber. This may not be doable for daily drivers.
- Andrew
smg1138 (06-20-2016)
Old 06-20-2016, 04:30 PM   #14
smg1138
smg1138's Avatar
- Andrew
I'm rockin' -3 up front and -2.5 in back so hopefully I should be ok.
I usually set my ride height even front and back with a full tank and all the trunk junk. That way, when I'm doing AutoX, it gives me a little bit of positive rake. Running 1/4 tank and taking out the trunk junk makes about 1/4" difference in the rear.
The Following User Says Thank You to smg1138 For This Useful Post:
Racecomp Engineering (06-20-2016)
coilovers, rce, tarmac, tarmac 2
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
Recommended tire choice for 18x9.5 +40 all round setup? KruszR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-18-2014 03:04 PM
Damper crosstalk ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-01-2013 02:21 AM
