Old 01-18-2014, 08:51 AM   #1
KruszR
Drives: GTS 86
Recommended tire choice for 18x9.5 +40 all round setup?
Hi guys,
Need some advise on tire setup for the following rims:
Volk Racing TE37SL Black Edition 18x9.5 +40 all round.
Looking at either 235/40 all round or 245/35 all round.
I won't be rolling either my front or rear fenders or removing any inner fender plastic parts. Will there be an issue for either setup on stock suspension?
Will there be any rubbing of inner fender tub or catching the outer fender lip on full lock and over bumps, etc., with either setup on stock suspension?
Scenario 2:
If the car is lowered about an inch, what will you guys recommend as best tire size setup with the least amount of camber that will not cause any rubbing of inner fender tub or catching the outer fender lip on full lock and over bumps, etc.?
Just want to confirm a few things before getting a set.
cheers!
KruszR is offline   Reply With Quote
Old 01-18-2014, 09:17 AM   #2
Ouhei
Ouhei's Avatar
Drives: '14 SWP BRZ Limited
Run at least a 245/35, if not a 255/35. 235 is too much of a stretch on a 9.5 IMO.
Ouhei is offline   Reply With Quote
Old 01-18-2014, 02:27 PM   #3
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
I'm running 225/40 on a 9.5 wide wheel and I'm stretched, I suggest you go at least 245/35 to not stretch.
Yamajee is offline   Reply With Quote
Old 01-18-2014, 03:04 PM   #4
donutfilling
donutfilling's Avatar
Drives: frs
You should run the 245/35-18. the 235-40 is too high a sidewall imo.
I would check the inner clearance as it should be very close if not hit the springs on stock suspension.
If lowered you would need a bit of camber to have it fit properly and look nice.
donutfilling is offline   Reply With Quote
Recommended tire pressure for Thunderhill I<3Twisties Tracking / Autocross / HPDE / Drifting 3 12-20-2013 01:50 AM
Recommended tire mount & balance shop in NNJ? fx35s NY / NJ / CT / PA 9 11-26-2013 06:00 PM
Daily Driver Tire Choice Poll brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 09-26-2013 02:38 PM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 01:28 PM
tire choice kendalldwhite Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-07-2013 10:48 PM
