aeiou
Drives: WRB BRZ
Brighter dome light that keeps dimmer function
I changed all my exterior bulbs to LEDs, and would have done the interior ones but I like the warmer yellow light. It's just not bright enough. I like the function that gradually brightens the bulb, apparently this feature goes away when you put LEDs in.
I never noticed, but I don't think this feature is present on the puddle/courtesy lights is it? |
Drives: 2014 Subaru BRZ (Limited)
for what your looking for in a bulb/ led, i don't think you're going to find anything. I'm thinking these are your only options
standard halogen bulb: warm white/ brightens/ mid light output standard halogen bulb: cool white/ brightens/ mid light output LED bulb: cool white/ standard dim/ low-high output LED bulb: warm white/ standard dim/ low-high output Keep in mind that the LED bulbs to dim in and out it just happens a lot faster. The bonus to the LED's is that they are available in a wide range of colours and brightness levels. you'll have a lot more choice. You'll also save on power consumption you're correct, the courtesy lights do not have the dimmer feature. its almost instant but the halogen does warm up a little bit. not very noticeable at all though. |
| The Following User Says Thank You to jbsali For This Useful Post: | unsurety (06-05-2014) |
| brighter fog light bulb for BRZ? | chenshuo | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 01-11-2016 01:57 AM |
| Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light | F1point4 | DIY (Do-It-Yourself) Guides | 9 | 03-25-2014 09:39 PM |
| Want to buy fog light stalk w. Fog light function only. | chriscross_tnt | Want-To-Buy Requests | 2 | 11-13-2013 12:58 PM |
| Interior LED Dome Light Diffuser | DIY | 6X Brighter | Dezoris | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 04-21-2013 08:59 PM |
