Old 05-22-2012, 05:46 PM   #1
trackmagic
Drives: 1994 BMW 318i
Billet Key Housing
I have seen a lot of tuners asking for ideas for things to build. I also see people complain the keys look cheap.
Maybe somebody should make a CNC'd-out billet aluminum key housing. You would just pry your plastic key apart and install it in the aluminum.
It might look cool. There would need to be some testing done to make sure it does not affect the keyless entry signal.
Anodize is World Rally Blue and carve back a Subaru-logo for extra bling!
trackmagic is offline   Reply With Quote
The Following User Says Thank You to trackmagic For This Useful Post:
chulooz (05-24-2012)
Old 05-22-2012, 06:08 PM   #2
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
I'd like a new case for my future BRZ-L proximity key
http://www.ebay.com/itm/TOYOTA-SCION...#ht_8744wt_809
illmatic is offline   Reply With Quote
Old 05-23-2012, 12:30 PM   #3
trackmagic
I think we could make a better looking key than that. When do you think you could buy unprogrammed keys? Maybe I'll try to get one and sketch one out.
Old 05-23-2012, 02:24 PM   #4
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Sticking the keyless entry remote inside a block of metal probably isn't going to work to well.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
civicdrivr (05-23-2012), Surok (06-20-2012)
Old 05-23-2012, 05:31 PM   #5
trackmagic
You might be right, but if there is a way to ground it to the case it might work. I did mention that might be an issue in my original post, but I'm not antenna expert so if you are please tell me.
I am pretty sure I have seen phones with metal battery covers that seem to get reception so it seems like either it does not matter or it needs to be grounded.
Old 05-23-2012, 06:05 PM   #6
neutron256
neutron256's Avatar
It might work but a good chance it will decrease range, or not work at all. Antennas can be very picky they have to be designed to work with the frequency. Add the fact that you'll become part of the antenna as you hold it in your hand.
Old 05-23-2012, 07:24 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
[ame="http://www.youtube.com/watch?v=0LgnnWov_H4"]Use your head to extend the range! - YouTube[/ame]
Old 05-23-2012, 08:06 PM   #8
neutron256
neutron256's Avatar
Seen that one and tried it. It works but I have no idea why.
Old 05-24-2012, 11:07 AM   #9
Calum
That Guy
Your head just happens to work well as a passive re-radiator for the signals frequency.
Old 05-24-2012, 11:18 AM   #10
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I was thinking of a different key fob too. Great idea and good luck, keep us updated!
chulooz is offline   Reply With Quote
*** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** zAnSh1n Cosmetic Modification (Interior/Exterior/Lighting) 21 04-04-2012 04:41 PM
