Old 05-29-2014, 05:12 PM   #1
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Blue Coolant turning green?
So i noticed my coolant was low so I went to the dealer and bought some. It was blue before i put it in and now its green/really dark blueish green. I assume its not suppose to change colors on you. Has this ever happened to someone?
rhood168 is offline   Reply With Quote
Old 05-29-2014, 06:29 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Several possibilities I can think of:
1) The dealer sells coolant different than what comes stock in then the FR-S and BRZ are shipped with (kind of doubting that)
2) Chemical reaction with the old coolant which has small metal particles from the block mixed with new coolant?
3) Maybe the mixture is wrong
Whenever I plan on adding coolant, I usually go the extra mile and just flush everything out anyway and replace it all with new coolant to prevent possible mixing issues, but that's just me
Old 05-29-2014, 06:57 PM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
What coolant did you buy? Did you buy the "Super Coolant"?
You could of bought the wrong Subaru coolant (the green one), which is "Long Life".
[ame="http://www.amazon.com/Subaru-Long-Life-Coolant-SOA868V9210/dp/B007L72U1C"]Amazon.com: Subaru Long Life Coolant, SOA868V9210: Automotive[/ame]
THIS IS THE WRONG COOLANT.
My coolant HAS NOT changed color. It is still blue.
N1rve
Old 05-29-2014, 07:25 PM   #4
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
It's probably because the coolant that's still in your pipes is green and it's just mixing with the lighter blue color Shouldn't be an issue!
Wilso is offline   Reply With Quote
Old 05-30-2014, 03:00 AM   #5
rhood168
rhood168's Avatar
Yep, they gave me the long life super coolant but its blue not green.(exact one in the pic and NOT the link.
I Hope your right =x ill keep checking and see whats up thx
Old 06-17-2014, 01:44 PM   #6
CaptDale
Drives: '14 BRZ
I work at a Subaru dealership. You need the premixed 50/50 Super Long Life Coolant (All Subs 2010 and up). Not the older Long Life Coolant that isn't premixed (Subs 2009 and older).
CaptDale is offline   Reply With Quote
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 04:56 PM
Green engine coolant used quickly? Tylub Issues | Warranty | Recalls / TSB 19 06-19-2013 01:15 PM
TC turning back on after turning it off Xdragonxb0i Issues | Warranty | Recalls / TSB 2 02-01-2013 04:19 PM
