Old 05-27-2014, 07:36 PM   #1
TmP
TmP's Avatar
Drives: A bunch of 'em...
Scan Gauge Help!!!
Alright, so I was super happy with my scan gauge, until about 10 minutes ago.
I used the oil temp code last weekend and it worked perfect.
Found an AFR code on here and wanted to add it.
Couldn't get it to work, got a cell.
Cleared the cell, but now the gauge is messed up.
Oil temp won't work any more either and the available signals and their 3 letter combos changed!!! WTF?
I tried changing the different CAN modes, but no luck.
Help please.
TmP is offline   Reply With Quote
Old 05-27-2014, 07:41 PM   #2
TmP
TmP's Avatar
U0073 was the code btw.
Old 05-27-2014, 07:51 PM   #3
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I've had this.
erase the new code that you entered by blanking the first character of the TXD (it might be one of the other sections, check in the manual on how to erase) then turn it off and on again.
86•BRZ is offline   Reply With Quote
Old 05-27-2014, 10:37 PM   #4
TmP
TmP's Avatar
I'll try a reset (if there is one).
All I have done to the gauge are the two codes, which don't work anyway...
Old 05-27-2014, 11:05 PM   #5
Lonewolf
Lonewolf's Avatar
Drives: Moped
Isn't this the code that is showed when there is an issue with the OBD2 port? Given the cheapy design of our obd2 ports these codes aren't all that uncommon...
Old 05-27-2014, 11:09 PM   #6
TmP
TmP's Avatar
I think it has something to do with me switching the CAN type by accident or something...
Not sure though.
The AC wouldn't come on anymore with the code up and the traction light was on...
Weird shit.
SSR Wheels,Miro Wheels, Websport & Stance SC5 19 8.5 F and 19 9.5 R b2autodesigns Wheels and Tires 710 09-10-2017 08:28 AM
Aeroforce Scan Gauge DIE1000DEATHS Electronics | Audio | NAV | Infotainment 5 04-17-2016 05:53 PM
Scan Gauge 2 - do I need a special version? TmP Cosmetic Modification (Interior/Exterior/Lighting) 5 05-18-2014 11:35 AM
Bluetooth OBD2 scan tool? Fast_Freddy Electronics | Audio | NAV | Infotainment 2 08-11-2013 10:34 PM
ATI Vent Pod 60mm & PLX DM-200 OBDII Scan Gauge Dustin@Dynosty Engine, Exhaust, Bolt-Ons 2 07-28-2013 01:21 PM
