Old 05-24-2014, 09:41 PM   #1
AtlasMick
Drives: FR-S 2013 Asphalt
Zed Amps, Stereo Integrity Subs, Hybrid Audio 3way front stage, Audison Processing
Here are a few pictures of the work I've begun.
System as it will be when finished:
(2) Stereo Integrity BM mkIV's
Here they are taped up for safety on mock up installation.
Which, I'm still on the fence about mounting regular or inverted.
(2) Minotaur III Zed Audio amplifiers, one for each subwoofer
(1) Leviathan III Zed Audio amplifer for the 3way active front stage
Audison BitOne for processing (external controller to be located in small cubby under HVAC controls)
Bass Knob for sub amp master, to be installed where USB/Aux jack is currently.
Hybrid Audio Legatia 6.5, 3, and R2 Pro tweeters yet to be installed. I hate it when equipment just lays around.
(1) XS Power D3400 hooked up to a toolmaker 2/0 double ANL fuse holder with 2/0 welding cable for the big 3 and one run + and - to the rear battery
(1) Small kinetic audio battery (can't remember the model) also hooked up to a 2/0 toolmaker fuse holder with a small custom fuse board made of plywood and mini ANL fuses
One thing I've noticed is that when you push a set of twelves in this car weird things start happening. I'll post some more pictures below of the progress along the way, and I'll keep editing this first post with the latest and greatest.
As of right now these subwoofers respond very VERY well to low power inputs, essentially they are super sneaky subs. When I am listening to classic rock, the bass is mellow and not overpowering, yet I can FEEL the rasp of the guitar strings. When cranked up however, be prepared for it because it feels like an electric shock when you go from nothing to full output from the amplifiers and a twelve immediately behind the seat and one another foot and a half away. I also listed to some heavy bass electronica, which made me feel like a was in a full body massage, my face even felt like it was going numb. At full tilt it feels like it is just barely started to make it difficult to breathe. The biggest downside to my install I believe is how I've used the sheet metal as part of the box. The upper end sounds a bit tinny and I believe this might be some harmonics. Even though I sound deadened and installed layers of fiberglass on top of the sheet metal, the panel still vibrates out to the rest of the car.
AtlasMick is offline   Reply With Quote
The Following 2 Users Say Thank You to AtlasMick For This Useful Post:
DAEMANO (06-18-2014), Shankenstein (06-11-2014)
Old 05-24-2014, 09:45 PM   #2
AtlasMick
Some more pictures of along the way:
Battery Mock up
Relocated all these electronics beneath the rear quarter glass
Putting together the high output alternator
Cutting the baffles
The Following User Says Thank You to AtlasMick For This Useful Post:
Old 05-24-2014, 09:45 PM   #3
AtlasMick
Reserved for whatever
Old 05-25-2014, 08:30 AM   #4
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Damn impressive so far. I'm going with 2 12's, but not this direction. I'm very interested in your progress!
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
AtlasMick (05-25-2014)
Old 05-25-2014, 10:52 AM   #5
AtlasMick
How deep are your subs, and what is the baskets' diameter? For this project some 12's fit, some 12's don't, and almost all 10's fit so long as they only require .5 to .6 cubic foot. But to be honest, I can't recommend this project after performing it myself. I doubt my airbag sensor is going to perform properly anymore.
Edit: Also some cutting is required, how much depends on how brave you are.
Old 05-25-2014, 12:26 PM   #6
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
damn....
Old 05-26-2014, 05:48 AM   #7
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
My subs are 5.75" deep, so they wouldn't fit. They also require ~.8 cu ft airspace. I keep changing my mind on how to install them, and probably changed my mind again this weekend. Luckily I haven't started (I'm out of town), so it's not too frustrating.
Old 05-26-2014, 08:43 AM   #8
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
Awesome so far! Can't wait to see how this turns out!
Keep it up!!
rmjjensen is offline   Reply With Quote
Old 05-26-2014, 05:12 PM   #9
labskaus
labskaus's Avatar
Drives: Toyota GT86
love to see more
labskaus is offline   Reply With Quote
Old 06-11-2014, 05:08 AM   #10
Z86
Drives: 86 GTS Auto in Pegasus White
@AtlasMick
Really keen to see pics of how you created the side enclosures. Thinking of something similar
Z86 is offline   Reply With Quote
Old 06-11-2014, 11:00 AM   #11
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
So... I thought you got a Singer Alternator a few months ago. Do something change?
The Singer unit seems like it will have better idle power, but it definitely makes me nervous about burning up the needle bearings at autox and track events. 7000 rpm * high ratio = lots of heat
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 06-11-2014, 02:08 PM   #12
WhiteFRS69
WhiteFRS69's Avatar
any updated photos??
Old 06-12-2014, 06:21 AM   #13
AtlasMick
I did, but had to send it back for paint quality. Still waiting to install it and it is a externally regulated unit. I'm working on the wiring now for the external regulator and 80 amp relay.
No pictures just yet.
Does anyone know where I might find an accurate LED voltage readout?
Old 06-12-2014, 05:49 PM   #14
Shankenstein
Frosty Carrot
Sorry to hear about the paint. I'm taking my time with this build... which is fine, since the stock system is pretty good.
My voltmeter is not the fastest or the best... but it lets me know when I'm running on battery vs. alternator.
Stinger Voltmeter: LINK to Sonic Electronix
The Following 2 Users Say Thank You to Shankenstein For This Useful Post:
AtlasMick (06-12-2014), DAEMANO (06-18-2014)
custom sub box w/ subs amps for sale BoostFed86 Hawaii 1 06-07-2017 11:00 PM
Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 slicktop Miscellaneous 1 07-11-2014 09:58 AM
RD Audio And PHD Amps! High Quality Sound!!! kmbkk Audio/Visual, Electronics, Infotainment, NAV 3 12-31-2013 10:44 AM
2 X 12" Subs, 2 X Amps and NOS Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 3 04-28-2013 11:38 AM
how to add subs to stock stereo fr-s chris's fr-s Electronics | Audio | NAV | Infotainment 10 11-30-2012 08:33 PM
