Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Miscellaneous
Old 05-12-2014, 04:34 PM   #1
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2
Item(s) for Sale:
Item(s) Description/Condition:
BRAND NEW - Opened for pictures, that's it. There are no scuffs on the mounting holes as you can see in the pictures.
MSRP $579
Power Ratings 100 watts x 4 at 4 ohm
150 watts x 4 at 2 ohms
300 watts x 2 at 4 ohms
Type Class D Full Range Digital
Protection Circuit 4 Way (Thermal, Overload, Short Circuit, DC)
Frequency Response 10 Hz - 40,000 Hz
Signal/Noise Ratio 105dB
T.H.D. @ 4 Ohm < 0.05%
Efficeincy @ 4 Ohm 86%
24 db Low Pass Filter 50Hz - 5,000Hz
24 db High Pass Filter 50Hz - 5,000Hz
24 db Subsonic Filter 10Hz - 500 Hz
Size 7" Wide x 2.25" Height x 12.00" Long
Item is in pristine condition. The only marks are on the bottom of the amp on the mounting surface (zero dents, just scratched). I've had this amplifier for 5+ years but it's been sitting in storage since Feb 2009. The amplifier has been verified in perfect working condition last week. Have some peace of mind that this amplifier is practically BRAND NEW in terms of cosmetics and usage. The price is firm, you won't find deals like this often.
Rated power output
----RMS power, 4 ohm stereo 100W x 4CH
----RMS power, 2 ohm stereo 160W x 4CH
----RMS power, 4 ohm bridged 320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
THD@RMS Watts <0.1%
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Wired Remote Controller
MSRP $549 USD
Great condition. Two small nicks, one on amp face and other on bottom edge; about the size of the top of a pencil. I've had the amplifier for 5+ years, it's been in storage since Feb 2009. Verified excellent working condition and great cosmetic condition last week. Barely any usage!
Type: Class AB Monoblock Power Amplifier
Ultra High Current MOSFET Devices
MMT Regulated Power Supply
35 Nanosecond Switching Diodes
High Capacity Power Transformer
Multiple Bypass Capacitors on Incoming 12V Supply
Time Delay Turn On with Opto-Coupled Muting
Pulse Width Modulated Power Supply
Thermal, Short Circuit and Reverse Polarity Protection
High Efficiency Class AB Design
Active Constant Current Bias Tracking
Dynamic Power: 800w
RMS Power (2 Ohms): 2 x 200W
RMS Power (4 Ohms): 2 x 100W
RMS Power (4 Ohms Bridged): 1 x 400W
THD: <0.03%
Channel Seperation: 58dB
Damping Factor: 250
Input Power Supply: 12-18 Volts DC
Signal to Noise Ratio: >100db
Frequency Response: 10hz to 50Khz -1.0dB
Low Level Input Sensitivity: 20mv to 6v
Selectable Crossover: HPF / FULL / LPF
Continuously Variable Low-Pass Crossover 40-250Hz @ 24dB / Octave
Continuously Variable High-Pass Crossover 40Hz-1KHz @ 12dB / Octave
Subsonic Filter: 15-40Hz @ 24dB / Octave
Bass EQ Control: 45hz - 0 to 12db
Line Outputs
Platinum-Plated RCA and Power Connectors
8AWG Power Connectors
Indicators: Power, Protect
Weight: 4KG
Fuses: 1 x 25 Amps
Dimensions (mm): 63.5(H) x 222(W) x 248(L)
Price:
VERIFIED PAYPAL ONLY
Incriminator Audio 6.4 - $375 shipped
Sundown Audio SAX-100.4 - $325 shipped
US Amps Xterminator XT800.2 - $75 shipped
Pickup accepted.
Shipping and Miscellaneous Item Information:
Shipped from 23665, insured for value rounded up, and packed very well.
Made a final thread to combine my car audio equipment for sale instead of bumping multiple threads. The amps have remained in storage in my garage in their boxes wrapped in plastic.
Item Pictures:
slicktop is offline   Reply With Quote
Old 07-11-2014, 08:58 AM   #2
slicktop
ttttttttttttttttttt
FS: Pa Car audio kicker comps, pioneer comps, kicker coaxials, 2 alpine amps, polk et SterlingBrz Audio/Visual, Electronics, Infotainment, NAV 2 04-27-2015 11:45 PM
RD Audio And PHD Amps! High Quality Sound!!! kmbkk Audio/Visual, Electronics, Infotainment, NAV 3 12-31-2013 09:44 AM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
Need some audio help jpit Electronics | Audio | NAV | Infotainment 7 03-15-2013 05:09 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
