Old 05-22-2014, 01:29 PM   #1
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
How to repair clear coat eaten by bird droppings?
Any tips or suggestions for repairing clear coat that has been eaten by bird poop? It must have been terribly acidic, because I cleaned it the day it happened, but it looks like it ate down into the clear a little. It looks rough. There are two locations, one on the hood and one on the cabin roof. Both about the size of a quarter. I already washed and clay barred last night. Any suggestions?
This is a regular occurrence for myself and my coworkers. Seagulls nest on the roof, and nothing can be done because the Port owns our building.
Thanks.
NWFRS is offline   Reply With Quote
Old 05-22-2014, 04:44 PM   #2
White64Goat
Car Cover ...............they might be a hassle, but is ruined paint not worth it?
The Following 3 Users Say Thank You to White64Goat For This Useful Post:
humfrz (05-25-2014), NWFRS (05-22-2014), radroach (06-07-2014)
Old 05-25-2014, 02:52 AM   #3
humfrz
Thanks.
Yep, get to and eliminate the root problem .... the makers and depositors of uric acid ......
humfrz
AVodka14 (06-13-2014), NWFRS (05-25-2014)
Old 05-25-2014, 08:50 AM   #4
dannyboy8793
dannyboy8793's Avatar
Drives: BRZ Limited SWP
LOL @ humfrs,
dannyboy8793 is offline   Reply With Quote
Old 05-25-2014, 12:05 PM   #5
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Only way is leveling the clear with a polish.
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Stay Fresh Car Care (05-26-2014)
Old 05-25-2014, 09:24 PM   #6
speargunsandracecars
Drives: 2014 BRZ
Using a Porter Cable with a very fine to fine polishing compound will get rid of it. Don't forget to apply wax afterwards.
speargunsandracecars is offline   Reply With Quote
Old 05-28-2014, 10:51 AM   #7
Junkman2008
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
[ame="https://www.youtube.com/watch?v=KsAizS6d064"]Bird Poop Etching Repair - Part II - YouTube[/ame]
"Marines - Making the other guy die for his country for over 200 years."
Junkman2008 is offline   Reply With Quote
Old 06-07-2014, 05:17 AM   #8
Poodles
Drives: 2015 Series.Blue
Originally Posted by Junkman2008 View Post
Ugh, that guy doesn't know how to use a clay bar correctly and scratches the hell out of the paint.
I'd follow Larry's advice here:
[ame="https://www.youtube.com/watch?v=fgHd1twCHYM"]How to Wet Sand a Water Mark in Black Paint - YouTube[/ame]
Main issue is that the BMW's paint is very very hard vs the twins having pretty soft paint. But taking that video on it's own is a bit dangerous. As a general rule he steps up on aggressiveness until the blemish is gone and wouldn't go straight to sanding unless it's necessary (keep in mind he does this for a living and works on priceless cars all the time as well so his experience plays into this).
If you don't feel comfortable doing such things to your car, you can always hire a detailer!
Old 06-07-2014, 11:17 AM   #9
Junkman2008
This coming from someone who doesn't even know how to fix paint? Now that's funny!
Lord knows, I've NEVER worked on anything more expensive than a Geo Metro so I must be a hack!
[ame="http://www.youtube.com/watch?v=-n9AZFYfH-E"]Minor Scratch Removal on a Lamborghini Murcielago - YouTube[/ame]
Old 06-07-2014, 06:21 PM   #10
Junkman2008
Originally Posted by Stay Fresh Car Care View Post
We will chime in here now. Wet sanding is very dangerous if you have no experience.
Yes it is, and that is stressed in every video that I have ever posted on the subject.
Old 06-07-2014, 07:26 PM   #11
radroach
Drives: car
Respect for the biz, I watched your video, but you were claying the same spot on a car for minutes on end, which seems completely unnecessary and you could see it adding more defects to the paint.
Old 06-07-2014, 07:34 PM   #12
Junkman2008
... and that damaged was REMOVED with ONE pass of a light polish. Also, the bird etching damaged was removed. So where's the issue here?
Add to that, it was aftermarket paint on that fascia, which is much softer than OEM.
Old 06-07-2014, 11:49 PM   #13
Poodles
Apparently I dunno what I'm doing because I don't make an ass of myself on youtube
You are a hack because you're using a clay bar as an abrasive.
Also, if you haven't heard of Larry, you're living under a rock...
We will chime in here now. Wet sanding is very dangerous if you have no experience. We talked to the OP over the phone and sent him our Refresh 3 polish with a few hex pads. Keep in mind the OP has no experience in paint correction. We want to start novice detailers off in baby steps.
If he can not remove this problem by hand we offered the OP a future deal on the porter cable 7424XP and our polishing pads.
Any paint correction is "dangerous" if you have no experience. Also notice I said:
Reading helps.
It's the equivalent of using a standard socket on a metric nut, sure it might work but you're using the wrong tools and it was never intended for that.
The issue is you're using clay bar as an abrasive. It's not the intended usage of clay, and you're teaching bad technique for claying.
Old 06-07-2014, 11:56 PM   #14
Junkman2008
Any tips for getting rid of sun baked tree droppings off Opt-coat? Wolfkiller Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 07-17-2013 11:44 PM
Clear Coat sierra Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 06-28-2013 10:21 PM
Clear Coat Help Mr. J Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 12-28-2012 10:22 AM
Opti-coat and Clear Bra benoh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 07-19-2012 07:53 AM
clear-bra or opti coat jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-06-2012 09:21 AM
